Is38 stock DP pass emissions?
brekdown29
J-O-O
GTI 7.5
If it's not tuned you will get a CEL. But you can easily find an IS38 tune for stock downpipe.
tigeo
Nope. You could get one pushing it hard but it's just a piece of hardware and will regulate boost per the ECU and if driven normally will not give codes.
sovietsky19
APR has an OE DP IS38 file for a GTI. Running it myself. It's a solid "easy button" option.
Does this apr oe dp is38 file pass smog check in CA? Or do i need regular is20 stock dp file? How long do you need to drive the car to set readiness before going to smog?
tigeo
You won't ever pass in CA with any tune is my understanding regardless of readiness, downpipe, etc. so you would need to flash to stock.
nosmirk
SoCal
DIB 7.5 DSG
Tunes must have CARB EO in order to pass. AFAIAW, many of the current OTS tunes (Cobb, APR, etc) have EO.
Aftermarket DP is different and won't pass visual unless you can prove it's a replacement for a failed OE DP, which is a pain in itself to get paperwork for.
tigeo
And even then you are out of luck b/c the factory DP had 2 cats, they have to be OEM-equivalent, not a race cat.
TCdaosithui
SoCal
APR stage 1 for GTI and R will pass smog in CA
EpicTech
Houston
MK7 GTI 6sp w/PP
As others stated, no CEL but you will not be getting the benefit of the turbo without the tune. The ECU will still feed it stock turbo parameters. MPG might also suffer, but that is just a guess.
