ourlee
- 3085 Pampas Streat
- 17 TT 17 GTI S
Are they the same part number?
thx.
thx.
Where should I start looking for a R manual transmission?
I don't think so since the R is AWD, there is probably an output shaft coming out of there and it has different ratios too.
You have a thread detailing this attempt? Super interested in seeing a manual being retrofitted to an 8SNope, into the TT.
I’m doing the research. I’m waiting to hear from a London dealer what the part number is for their 2015 TTS quattro manual transmission. If this number matches the Golf R, I’m good to go.You have a thread detailing this attempt? Super interested in seeing a manual being retrofitted to an 8S
Thank you!Any FWD MQ350 would bolt right up to the block, but FWD MQ350 castings lack bevel box mounting points. The bevel box is how VAG transaxle cars send power to the rear driveshaft. The bevel box bolts in between the passenger side axle and the trans. The passenger side axle flange passes through the bevel box and is subsequently than its FWD counterpart.
If you buy an R/Alltrack transmission without the bevel box your DQ350 one should bolt right up.
Here's a Mk7 Golf R Trans code QPP(Bevel Box not attached)
Here's a Mk7 GTI Trans code NBL
