golfdave
- Scotland (U.K.)
- Mk7 Golf GT Estate
I will do that and update you
could you suggest coilovers with dcc option?
thank you
If the spring perch doesn't require moving you can use any coil overs you want..your choice.
If you have to move the spring perch & don't want to cut the bodywork, then the only coilovers that are made for the rear are the non-DCC competition spec...
Normal coil over kits have separate springs for the rear as this uses the existing factory spring placement.
The only thing you can do is measure it up, look at the bodywork in person & swap the multilink stuff across as its just a simple undo nuts & bolts & then swap......if the spring top is not mounting correctly then you know what has to be done..if the top of the spring fits the you can order whatever springs/dampers you want..
