dequardo
- America’s Dairyland
- ‘21 GLI Autobahn GLI
I was hooking up my wireless phone charger (see Wireless CarPlay thread for more detail on that) and in doing so moved fuse # 40 from the top to the bottom position in order to make what I thought was a change to enable power to the 12v DC ports. I was under the impression that the top position was for constant power and I was having trouble getting the port to be energized.
In any case I now had power there. Interestingly the power did go off with the door opened.
A couple days later I realized that neither the right side mirror signal, the mirror adjustment motor OR the two passenger side windows worked.
I had assumed the recent dynamic turn signals I installed had failed on the right side.
Yesterday before I started to figure out WTH was causing this I happened to put the F40 fuse back in its other position. Voila’. That fixed everything and I still had power at the plug.
This is a 2019. Of course VW no longer has any fuse diagrams in the owners manual. Grrrrrrrr
I can only assume something changed with either the 7.5s or the 19 models. Anyway posting this so I can hopefully save someone else any grief down the road.
