shortyb
- Upstate SC
- Felon Taxi,Dad Wagon
You might be thinking of my logs. I've got the same thing going on with EQT E30. Turbine actuator at 100% for much of the time and boost pressure between 1 and 2 psi below target. Iat higher than they probably should be vs ambient as well.
Seems something isn't quite right but aside from a cursory leak test where 30psi revealed nothing, I haven't done much investigation. It's too hot out to care yet.
Yep, all the logs kinda blur together I suppose. You have the Majesty though and car runs pretty well despite the numbers in the log if I remember correctly. I was thinking about that the other day, have you had the MAP sensor out of have a boost tap?
