Intercooler performance
mk7gti2.0
De Soto, MO
Don't know why anyone would spend almost 1000 bux on a intercooler..but the 240 bux I spent on the majesty intercooler works amazing at WOT it drops to a cpl degrees above ambient sometimes it's even with ambient temp. Works just as good as the rest for a quarter of the price.
Gptuners
KY
2019 GTI S
I can't speak for everyone else, and I actually haven't dropped that kind of money on an intercooler yet. I have gotten to the point where I would rather give the extra money for fit and finish from a company that actually does their own engineering.
Most times the price difference isn't in the performance; the company often has to pay for the research and development that they spent to create that product for us. I like to spend my money with those companies, or craftsmen that make you something that no one else will find in a catalog. I'm a sucker for pie cuts on pipes, but big companies tend to not like those. ?
Navi
BK/NYC/Hamptons
I have the AMS IC on a GTI and there wasn't a screw that can push into the AC condenser.
there used to be. They have since started sending a replacement screw after 2 damaged radiators. It's the 10mm black bolt that they include.
Navi
BK/NYC/Hamptons
It’s the bolt that goes through the hood latch. AMS thickness allowed it to puncture the ac condenser. They put a shorter bolt in their kits after that.
beat me to it
mk7_bk
I couldn't even find it, the only one on ams site is golf R FMIC
Ah the applications:
  • VW MK7 Golf R
  • VW MK7 Golf GTI
  • VW Alltrack
  • VW Passat
  • Audi A3 – S3
  • Audi TT – TTS
I guess people are choosing this because it is pretty good and up to 800hp (which noone has) expensive at 900 tho
Edit 2, says fmic but its stock location
J Peterman
Not sure the thread pattern. I think it’s m6x1.0 but have to double check.
Got an email back from AMS re: hardware for the intercooler.
Washer: 18-8 Stainless Steel Oversized Washer Black-Oxide, M6 Screw Size, 6.4 mm ID, 18 mm OD
Bolt: High-Strength Flanged Hex Head Screw Class 10.9 Steel, M6 x 1 mm Thread, 16 mm Long
billbadass
your moms house
I think I'm going with APR instead of AMS actually just because APR is bar and plate (which is my personal preference) and it looks like R&D at APR was done to optimize the internal fin density, etc so while I think APR is fairly slimey company with poor customer service I'm going with their intercooler.
OBP
ChiRaq
Considering the size of these I/Cs, they’re all rated for more power than us 99% will ever come close to.
APR doesn‘t manufacture or have made custom cores for them for their ‘R&D’. They‘re simply regurgitating they’re sourced core‘s advertising. The ETS IC from my old EVO used this same “optimized staggered fin” design back in 2005.
If we assume the generalities of B&P vs T&F cores, yet both are rated to roughly the same power levels : would you rather have an IC that cools 5* cooler vs one that flows better AND is lighter?
i don’t have the APR but do have the AMS. What i can tell you is that there is no heat soak and resulting temp increase throughout the 1/2 mile run. What I can tell you that in day to day driving, when you get into boost, it cools well enough to be around 2-3* above ambient in temps less than 60* and around 8* higher when temps are warmer.
