Installing Springs - Alignment Specs
aloha_from_bradley
AZ
2019 R
Front crash & lane assist camera system
Pulling the trigger on Neuspeed wheels & springs this week. I have a couple questions for others that have done this.
Question 1:
How does the alignment work out after the spring install? What did the specs look like?
Question 2:
For others that have a MK7.5, was a recalibration of the camera system necessary during the alignment?
I see lots of MK7.5s out there that have springs installed, but there is surprisingly little information about how the alignment worked out afterwards. I know a tech that works for Mercedes who's telling me I don't need the camera system recalibration, just to get the alignment done at a specialist.
The Neuspeed springs are a 1" drop. Obviously I'd like to get the alignment specs as close to factory as possible, but the dealership wants $600 for an alignment that includes the camera recalibration.
Any insight from someone who's done this would be greatly appreciated.
GolfRRRR1
Michigan
I have not installed springs yet, that being said I WOULD NOT get the overpriced camera recalibration unless you have issues. 100's of people on these forums have done spring installs and never needed to 'recalibrate' the camera.
I have done an alignment at a local shop and they did very good work. With springs you're just gonna get a little more camber (like -.75 or so) it won't make a difference to the car or tire wear at all. Good luck, btw a 4 wheel alignment should be about $89-$119 total.
aloha_from_bradley
AZ
Thanks for the reply.
Yes, I understand what you are saying and I'm totally on board. I also understand what acceptable tolerances for alignment specs / what expected & reasonable prices are as well. My main issue is the camera system and whether or not it will need to be calibrated. Also, was wanting to know how far out of spec the car will be pre alignment, but after the spring install. This will give me a good idea of what to expect when the alignment is completed, spec wise.
From what I can tell, the camber will be slightly out of spec - like .2 degrees or something in the front. I'm not worried about that as I doubt it will have an impact on tire wear. Obviously toe will be adjusted.
I just don't want my car slamming on the brakes thinking there is an object in front of me or something to that effect - or potentially having issues with the ACC system not working. There is a chance that "finding out if I have a problem" means smashing into another car, or getting rear ended because the system abruptly causes the car to stop.
new R Fan 2018
Orlando,FL
I didn't have any sensors recal'd after installing springs/alignment. Haven't noticed any diff either.
aloha_from_bradley
AZ
Thanks, guys.
I called the dealership back and just asked my advisor about the alignment. He's just going to charge me the "performance" alignment fee rather than the full calibration. Should work out just fine, fingers crossed.
