Waltari
- Portland, OR
- MK7 GTI
No offense taken and I'm glad it's worked out for you. Honestly, it was mounted exactly as you're noting and when I inspected it I didn't find anything had broken. I've found more instances online of people with similar issues and it does seem odd they no longer install them.Don't take personally but hard to see how they fall off if installed correctly. Held on by three locations. One is a hook so not a secure spot on its own. One is a ball and rubber cup connector like on engine cover, so if on well holds on. The third is a long center arm that clips into a hold. To remove the clip has to be pressed in order to pull out. If long arm clip working and locked in and rubber cup/ball installed correctly it should hold. I have had mine for 6 years. On my second one because I forgot the left side is a hook and not a cup so pulling this side not good. Even with broken hook on left side it never came off.
