George Ab
- Pacific NW
Documenting this in case anyone has a mysterious intermittent dead battery and are unable to find cause. My battery would be completely drained and it was an intermittent problem. Battery would go days without a problem and then suddenly dead. After ruling out the obvious of a bad battery, performed all the normal failure analysis for trickle drain (looking for micro voltage across fuses) etc. which was unsuccessful. After many months of disconnecting battery at night, I was doing something in my car and the infotainment unit turned on by itself. I then put a switch in-line with infotainment fuse for a few weeks which verified the problem was the head unit. Replaced head unit, removed CP (component protection) Functional enablement codes (FeC’s) and problem solved. The problem unit was an early MIB2 3Q0035844 which I swapped with a 3Q0035844B. Jack Kirry removed component protection and reinstalled the FeC’s. https://www.golfmk7.com/forums/inde...o-mib2-infotainment-conversion-part-1.343701/
