Hey all,
Wanted to try and keep better track of what I'm doing to this as I get deeper into it. Got into the golf after building a hybrid turbo 335i, and overall this is just a better platform and community. I think these are very capable cars and I'm keen to see how far they can be pushed.
To start, current mods:
Power
IE v2 CAI
CTS TIP
APR TIP
034 TMD
IE TIP
034 hose + aem dryflow filter
APR Pex Intake
VWR R600 intake
EQT Vortex XL + PTP blanket
Garrett Powermax GT2260s w/ cerakoted turbine housing
IS38 ball bearing conversion by Turbo Concepts
Littco L380
Unitronic throttle/outlet piping
ECS intercooler
Do88 Intercooler
Do88 Radiator
CSF aux rad + dsg cooler
CTS high flow downpipe
Trackslag 4" high flow downpipe w/ cerakote
GESI 400cpsi cat
AWE switchpath exhaust v2 + vibrant 17950
Leyo catback
4/5 bar PUT/MAP sensors
A2B 925cc MPI + flex sensor
Bosch direct injectors
PPT Brushless LPFP
RS3 LPFP
UM flex tune
8 bit performance flex tune (RIP)
Russell Road & Racing ecu/tcu tune
NGK R7437-9
Denso IHK24
Denso IKH01-27
RS3 NGK plugs
APR sparkplugs
Denso IKH01-24
ECS catch can + Spulen V2 PCV plate
APR can + plate
Bar-tek oil cooler v2
Fluidampr crank pulley
Drivetrain/Suspension
BFI stage 2 motor/trans mounts
BFI stage 1 dogbone insert
ECS dogbone arm + powerflex hybrid insert
Unitronic dogbone mount (race)
Eurocodefront/rear strut bar
Superpro 26/24mm front/rear swaybars
Superpro/whiteline adjustable endlinks
Whiteline WA302L/R front LCAs + powerflex black rear bushings
8Y RS3 front LCAs
Audi aluminum front subframe
CTS subframe collars
DSC Sport controller
Eibach Pro-kit springs (linear)
Ohlins Road & Track (7k/8k swift springs)
Clubsport S Knuckles
Vorshlag camber/caster plates
Whiteline adjustable balljoints
Superpro RTABs
034 adjustable toe arms
SPC rear camber arms
Superpro rear wishbone/knuckle bushings
TB Performance rear chassis brace
Mountune52 rear chassis brace
Quaife QDF33R front diff
Wavetrac rear diff by powerzone/haldex-lsd.
Powerflex black diff bushings
Wheels/Tires
235/40/18 Potenza Sport + 18x9 Neuspeed RSE11R
235/40/18 DWS06+ + 18x8.5 Neuspeed RSE10s
245/40/18 v730 + 18x9 Apex SM-10
motorsport hardware studs
Brakes
8J TTRS 4-pot front brakesw/ RB vented pistons
Girodisc 370x32mm front rotors
RS3 brake ducts
VBT billet steel adapters
Racingbrake front + rear rotors
Mk6R front brembo blanks, centric high carbon rears
DS2500 pads
Carbotech XP10/XP8 pads
TCOFF street pads
RBF600
RF650
Neuspeed/Hel lines
Interior
Stern Performance Clubsport Rear Delete Net/carpet/bar
H3r extinguisher + Rennline seat bracket
Schroth Quickfit Pro
Exterior
Raceseng Tow Hooks (bit flashy for me but a tow driver took my hook cover off and it's never stayed on since).
Aerofabb V2 Street Splitter
Mk7.5 GTI TCR Rear Spoiler
Won't do some full write up on the path this car has taken, but I bought it in Jan '20 with about 6k on the odo. Went through a pretty quick progression from stage 1 cobb to stage 2 FBO with an EQT tune to a vortex. By October the car was on a road trip out to Denver and things worked out where the fastest (and by no means the cheapest) way to get it into the canyons was a UM tune at Bluewater. Had it re-tuned for 93/low alt back in Chicago, HPA HPFP took a dump in the process so I picked up an MPI kit and went back to the UM dealer for a flex tune.
That's roughly where the car's been since December, I was fighting overboost issues ever since picking it up from the last UM tune. Took it into my usual shop, and it happened to be a week where the car didn't feel like acting up. Decided to just replace the whole actuator setup with a housing upgrade and while we're in there and getting re-tuned, do the Trackslag pipe. Just waiting on a shop appointment.
Power
CTS TIP
APR TIP
034 TMD
VWR R600 intake
Littco L380
ECS intercooler
Do88 Intercooler
Do88 Radiator
GESI 400cpsi cat
RS3 LPFP
Denso IHK24
Denso IKH01-27
RS3 NGK plugs
APR sparkplugs
APR can + plate
Eurocode
8Y RS3 front LCAs
Superpro RTABs
Wheels/Tires
Brakes
RS3 brake ducts
TCOFF street pads
RF650
Neuspeed/Hel lines
Interior
Exterior
