Great build and direction of path. What’s the “HPDE” rate?
Thanks! 475F/650R. Significantly higher than stock hence getting my B8s re-valved.
Trying real hard to clean up my pile of parts before summer. Main thing right now is waiting on the turbo job, primary o2 had to be replaced and the part for '19+ cars is scarce apparently.
Still sitting around: toe arms, trailing arms, rear camber arms, rear wishbones, css knuckles, ttrs brembos, rs3 ducts, csf radiators, oil cooler, dsg breather.
Also going to throw the euro tails on at some point, go back to the stock catback with a res delete (weighs less and is not a bottleneck on the Powermax). Ditch the a2b rail for an OE MPI setup. Might do an aluminum oil pan. LMS/TCR dealer never got back to me, but I would still like to try the TCR setup (-6AN drain to the sump with a check valve).
Waiting on:
PDC vented hood. Maybe july?
Bilstein + GC coilover - mid-may
Wavetrac - not ordered but want to get a pre-order in for the front diff. I'll do the rear eventually as well, maybe next winter.
After all that, it's pretty much done for the time being. Eventually I'd like to get a roll bar, fixed-backs, and whatnot, but that's full commit. Both in terms of really limiting street driving and drilling the chassis for backing plates.
