~IN STOCK SPECIAL~ GFB DV+ for MK7 GTI/Alltrack
Aristocrat Autosport
GOLFMK7 Official Sponsor
Buena Park, CA
GFB has provided MK7 owners with a very simple solution for the weak factory Diverter valve with their DV+, a direct fit unit which retains the factory solenoid coil for seamless integration. Through their research, GFB discovered that the solenoid coil used in the factory diverter valve was great, however the valve mechanism itself uses a diaphragm prone to rupturing and plastic piston prone to leaking due to poor design. The DV+ fixes this problem with an anodized billet aluminum housing with a brass piston machined to exact tolerances which attaches to the factory solenoid. This all results in sharper throttle response with proper valve actuation and a massive boost threshold compared to stock. The DV+ requires no unnecessary hoses/lines to run compared to other DV replacements.
This will not work with some aftermarket turbo inlets as the DV+ spaces out the factory diverter valve, reducing clearance.
PM with your zip code for an accurate pricing quote! SoCal residents can will call from our Buena park location.
Facebook: https://www.facebook.com/AristocratAutosport/
Instagram: https://www.instagram.com/aristocrat_autosport/
Website: Aristocrat Autosport, LLC - .:Building Your Dreams Into Reality:. - Homepage
CALL OR TEXT: 714-340-6596
Email: Sales@AristocratAutosport.com
