In process: Alibaba GTI build
golfRdaddy
Bakersfield
17R / 16R
I'm sure Charles bought it from Co-Part or a Co-Part partner. After tax and fees, I bet he paid 20k or more for the salvage rs3.
The motor is not hard to pull.. I did it alone. If you have tools and know how to turn a wrench anyone could do it. If you don't get an assembled long block, well that's a different story.
CT
2017 Audi TT
Getting it back in and running is the part I'd be concerned about...
geokilla
Toronto, Ontario, Canada
2018 VW GTI DSG
How much would it cost a shop to do a complete engine swap? $3k labour? I assume it'd take them 3 days?
Mksleven
Texas
MK7 gti
Ballsy to do alone, but I agree, it can be done. I’d never pay someone to do a long block replacement for me..saving $~3k and learning the ins n outs of the engine/engine bay is worth it if you plan on keeping the car ~
GTI RobG
New Jersey, USA
2018 VW GTI SE
I almost have my motor out. With the weather, I haven't spent much time on it. Still haven't been able to get my front wheels off.. I lost the lug key. Just need to disconnect the rear axle now and then it should come out.
Can anyone help me find the right lug key?
Another question I have is .. I was reading someone bought a built motor for their R but it was originally in a GTI. He had issues with the swap because of a port that was open on the head or block. If anyone has any info on that please share.
Looks like 532 to me.
Mksleven
Texas
MK7 gti
Update:
I’ll be ordering another long block but I’ll be building it myself w/ the help of local machine shop. Tried getting them to assemble it for me but I couldn't justify the cost/risk of sending all the forged items over there ($~2k worth of parts..$450 to ship via FedEx without included taxes/tariffs/etc) and also the likely lack of experience working with forged items and all that. I’d rather put my hands on it than not, and learn along the way.
I’ll be paying $1650 for the new long block shipped to my door. I’ll tear it down once it gets here and get started…forged rods/pistons, ARP head studs, SuperTech valves and valve springs ?
If anyone has a full list of one-time use bolts (and links/part numbers) that would be super helpful so I can order those now and have them ready ~
I think I’ll make a new thread for the tear down/build too
Mksleven
Texas
MK7 gti
Oh and if anyone wants to buy a long block for the same purpose maybe we can get it cheaper if bought in bulk..haven’t asked what the savings are tho
Diggs24
de plains! de plains!
2015 GTI
Rear main 06H103171A
Front main 06L103085B
Valve cover sealant- ELR-509860
Spool valve seal - ELR-302690
Timing cover gasket- 268000
Con Rod ACL - 4b5562h-std
Metal oil pan- 06j103600e
ARP Rod bolts - 200-6209
ARP Headstuds - 204-4302
Turbo oring WHT006113
Turbo oring WHT006124
Turbo oring WHT006114
Downpipe gasket - 5Q0253115B
T Oring WHT006112
Turbo mount nuts WHT007210 x4
Turbo gasket - 06L253039
Valve cover bolts- N10554005 x22
HPFP Oring - WHT005184
Vacuum Pump Gasket 06H-103-121-J
Fuel Injector Seal Kits 06J998907D x4
Turbo oring N90067202 x2
Cylinder Head Nipple Breather- 06K 121 143
Oil Filter Hosing Bracket Gasket - 06L115441
Dampener Bolt - WHT009475
Pilot bearing 06B105313D
Crank main bearings - need color
Flywheel Bolts N90665001
Trust Washer - WHT000033N
PCV Gasket - 06K103484B
Head Gasket- 06K103383K
Upper Oil Pan Bolt Big M8×85-N10765501 ×2
Upper Oil Pan Bolts Inner M8×30-N91211201 x5
Upper Oil Pan Bolts Outer- M8x20-N91048802 ×11
Main Cap Cross Bolt N 911 875 01 x6
Main Cap Bolts - N91118902 x10
Dipstick Oring- WHT-003-463
2x Thrust washer WHT000033N
Intake Manifold Gasket - 06K-129-717-A
06H109469AH Engine Balance Shaft Chain Guide (Lower Right)
Timing cover gasket 06L103483A
06H109467AR Engine Balance Shaft Chain Tensioner Genuine
N10554005 (2) Chain Tensioner Bolt Genuine VW
N91130401 (6) Chain Guide Bolt (Lower Guides) Genuine VW
N91130301 (2) Chain Guide Bolts (Upper) Genuine VW
06H109469AQ Engine Balance Shaft Chain Guide (Lower Middle) Genuine VW
06H109509P Engine Balance Shaft Chain Guide (Lower Left)
06H109509Q Engine Timing Chain Guide (Left) Genuine VW
06K109469M Engine Timing Chain Guide (Right) Genuine VW
06K109467Q Engine Timing Chain Tensioner Genuine VW
06K109158AM Engine Balance Shaft Chain
06K109158BJ Timing Chain Genuine VW
Mksleven
Texas
MK7 gti
T Oring WHT006112
You the man. Thanks!
geokilla
2018 VW GTI DSG
Charle's DAZA is so sus.
wascally wabbitt
Southern Maine (aka Northern Mass)
2017 GTI S
T Oring WHT006112
You dropped this, king ?
