Hi guys!
I wanted to share with you one of my latest modification that I did to my Leon MK3, because I believe it should interest at least someone on this forum and it is definitely applicable to the Golf MK7. I've successfully installed illuminated outside door handles from AliExpress!
Quick summary of links:
First I was worried that they will be some knock-offs from very cheap plastic but I was surprised when they arrived. They have VW logo and part numbers which suggests that they are OEM handles for Chinese T-Roc.
I don't know color palette of Golf MK7, but black and white color of those handles does not match Leon MK3 colors so keep in mind that they probably need to be painted before installation.
Handles are connected to the 1st pin of 16-pin connector in the door modules (plus) and 3rd pin of the same connector (minus). In Leon MK3 rear door handles are connected to the front door modules, because there are no rear door modules.
After installation there is only one thing left to do and it's coding time - activate bit 0 in byte 1 and everything should start working!
This one is a video and you have to click on the thumbnail to see it
You can read full details and discovery here: https://www.seatcupra.net/forums/threads/illuminated-outside-door-handles.476137/
- handles without keyless: https://s.click.aliexpress.com/e/_DBdvzmB
- connector for handles without keyless: https://s.click.aliexpress.com/e/_DBs59Nd
- handles with keylesss: https://s.click.aliexpress.com/e/_DmCBKgB
- connector for handles with keyless - pretty expensive, it might be better to order complete wiring: https://s.click.aliexpress.com/e/_DC0Mlg3
