Jimdog
- Half way down the track
You can install the turbo blanket without taking anything off. You will have to pull the downpipe to wrap it but that's pretty easy.
Forge is lava or fiberglass?I was able to reinstall the OEM heat shield on top of my Forge blanket.
What seems to be the best fitting blanket out there? Are there ones with good fit without having to safety wire?
Keep your receipt. had one on my WRX. Tore right at the stitching..they replaced...new one did same, noticed when I returned car to stockin my shopping, I can't recall seeing one without safety wires.
I would think you want the wires to stabilize the blanket as the blanket could interfere with the diverter. I bought the Thermal Zero (haven't installed yet) as they claimed custom fit and their photos suggest they did a decent job fitting around the diverter. Still, they use wires that run beneath the diverter
thanks, will doKeep your receipt. had one on my WRX. Tore right at the stitching..they replaced...new one did same, noticed when I returned car to stock
Sometimes you get what you pay for, and sometimes ya get a bargain for what the Forge appears to be. There are some blankets with exotic materials, but on the stock turbo it looks like the Forge is the way to go. I appreciate the insight.The Forge blanket doesn't come with safety wire, just springs.
That being the case, I've had zero problems with interference with the wastegate actuator. Plenty of clearance if it's installed correctly.
Few thousand miles on mine now and I'm super happy with it, especially given the price it cost.
Huge cut in underhood temps.
UPDATE:
My intake temps during August heat are hitting about 150 with the A/C on when parked. The EQT stage 2 tune is still happy at this temp. So far I still have no regerts.
