daymoon
- Portland Oregon
- 2017 GTI Sport
Can’t entirely rule the rings out that I purchased yet on Amazon, they’re aluminum, though I’ve heard conflicting reports on how some don’t fit the hub properly as it has a flange on the endI chased a similar issue,.
bought Konig HyperGrams and mounted my already used Conti Extreme Contacts to them.
bought Konigs plastic centering rings.
bought a good 1/2" torque wrench and used the proper method of tightening. Star pattern in increments up to about 50 lbs. Then lower tire to make contact with the ground enough to not spin and send it home.
I had a vibration at 60+ felt like it was the back wheel. swapping wheels/rings around didn't seem to move the perceived location. I assumed it was a rim. I had my cousin ( a master honda mech ) mount/balance my tires.
Still I had the balance re-checked at a local tire discounters. No adjustments were made and very little weight was used on any of the wheels. In fact only 3 of them required any weight at all. Nothing was bent, wheel bearings are okay, bushings are okay.
No changes. still have a vibration.
I then bought another set of plastic rings from Amazon.
Still vibrating.
Finally I bought a set of metal rings from Amazon, applied anti seize on them very carefully ( you don't want it on the hub face ).
- Metal Rings fixed my issued.
I went through two sets of rings before I found some that didn't vibrate.
I understand that an alternative might be switch to studs / nuts. It centers the wheel different since the studs are static and the nuts now have enough play to "pull" the wheel into correct alignment. I'm not sure how true this is but it seems reasonable. That said good stud conversions are sort of $$.
Good luck!
Here’s a picture of the rings tire rack supplied, they’re about the same depth as the aluminum ones I have on now (tire rack on front, aluminum in rear) still feel vibrations in pedal and floor past 60 mph. Do you happen to remember the brand you purchased from? I’m still considering ordering a set from BFI.
