so HP tuners got flex enabled before Ecutek or cobb? That's shameful, lmao.
so why haven't any US companies aside from UM figured it out? The euro crowd is all about it."Flex"...it's just a fueling adjustment which is already native in the ECU.
Actual flex would be adjusting timing also.
But if it adjusts LTFT based on E% that is a great start."Flex"...it's just a fueling adjustment which is already native in the ECU.
I have fueling for full E85 but have LTFT "zeroed" to about E50 since I dont need more then E35 for my timing advance with Is20. If I run E85 my LTFT end up at over 20+ and fueling control is not optimal.The ECUs do a fine job correcting real time so it's never been a huge issue for mild blend setups. At a certain point though you could hit the LTFT limit though (I am not sure what that limit is).
Either way, I like the idea of correcting before trims/feedback. And it's really easy to do/ECU has tons of logic for this...so why not?
The ECU also has 'virtual' flex, based on lambda feedback / no ethanol sensor required. I've never tried it, but there's a whole lot in the documentation about it.
I recently acquired a 2015 GTI and I have been using HPtuners to tune it.
Quick abbreviated background on me. I tuned my 2018 Alltrack with Eurodyne Maestro and in a previous life, I tuned thousands of Mitsubishi Evos from street to track/time attack use. I also dabbled in Ford Fiesta ST tuning as I owned a couple and tuned a bunch. My current personal Evo 10 makes 640whp on E85 (tuned by me) and is set up for track use.
So, no stranger to tuning. However, the MQB ECU's are a bit more sophisticated compared to Evos. I bit closer to the Fiesta ST.
Anyway... I'm having some issues with the GTI compared to when I tuned my Alltrack on Maestro.
Is this a good thread to ask questions?
Here is the latest log. I already think I might have too much timing but please take a look: https://datazap.me/u/razorlab/2015-...&solo=1-3-4-8-9-10-16-17&zoom=338-429&mark=50
