So, today did the TPMS button, because I already have the 3 buttons on the right quite a while. Thanks
@golfdave, for making this guide long a go.
Because I already have quite some time retrofitted the 3 buttons on right side it started to disturb me that this button wasn't doing anything, just like "mode" and "esp off", so this morning I literally googled "retrofit tpms set button golf 7", and found this topic.
I did read first few posts and decided to do the retrofit directly. During installation I already mentioned based on what I read, that ESP off couldn't be to hard also, so I immediately pulled a second wire and source it out later. I just now read all post in this topic, and I am happy I pulled the second wire directly. Will do connect the "esp off" button soon also.
Wire from any switched 12v supply (I used the same location on the EPB as I did in the above guide) to pin 10 on the T10ks connector for the SET! Switch module.
At first I read to fast and missed this part
. So I pulled
the wire from switch to ABS, did test, and,,,, nothing
At first I thought, did I mix up 1 of the 2 wires that I pulled? But after rereading the DIY I quickly found out what's wrong, no 12v supply.
So, ESP OFF will also work, and going to do that soon, but, MODE button, could I do some with this button also? I dont have DCC or DSG, but could it be used for example ACC driving profiles?
Happy to hear,
Greets Chris
