golfdave
- Scotland (U.K.)
- Mk7 Golf GT Estate
Disclaimer:- This info is for community usage. I am NOT affiliated to, or sponsored by, any company/individual to promote them or their products. Companies/individuals may NOT use my name, photos, or threads/technical guides, for financial or personal gain (fraudulent misrepresentation).
Part 1 of 4
Vehicle used in this guide
UK spec, 2014yr model, Mk7 Golf Estate (GSW), GT (Highline) trim, 1.4lt TSI (140PS) CHPA petrol engine, MQ250 6speed manual gearbox, multi-link rear suspension.
Vehicles that this guide is applicable to
Any Mk7 Golf which does not have this button fitted.
Special thanks to
Forum member “DV52” for answering technical questions I had in relation to ERWIN wiring diagrams.
Introduction
VW designed the layout of the Mk7 Golf dash with a TPMS button possibly due to uncertainties regarding the legal requirements for a manual button (in lieu of via the touchscreen infotainment) in certain countries. I first saw some basic pictures of someone doing this retro fit over 10 months ago on the drive2.com (Russian) site, & I completed the modification on my car in May this year (2106).
Research
There are only two types of ABS/ESC units for the MK7 Golf, one for manual handbrakes, & one for electronic handbrakes, & this “OEM mod” works for both ABS/ESC units. The existing row of three blanks, with or without one or two buttons, down the right side of the gearstick is one whole unit! This unit is the same for left & right hand drive cars, & Manual or DSG gearboxes.
Have you ever wondered what that top right blank button space is for by the gearstick even on a fully specified car?? Well guess what, it’s for the old TPMS button! Remember those in the MK5 & MK6 Golf’s which had the button, well VW decided that spending 12 seconds (fastest I have done it) going through the “infotainment screen” is better for us! So From the information that I have (& as far as I can tell), there are only two types of ABS/ESC units for the MK7 Golf, one for manual handbrakes, & one for electronic handbrakes.
This doesn’t even show up on the German ETKA for Germany etc. So Basically VW HQ designed the car for it & basically dumped the button for cost cutting but VW China kept it for their market!!!
Bosch make the ABS with all 46 pins on the ABS unit side of the connector. However VW Europe for our Golf only connect up with 32 pins max according to their wiring diagram. So there is a separate pin out for each of the ESC & the TPMS buttons. The same functions are transmitted over the CAN-gateway from the CAN out pins on the ABS unit to the infotainment unit. So as per most MK7 Golfs the ESC & TPMS buttons are not fitted & the only way to use these functions is to do it via the touch screen of the infotainment system.
However there are well reported problems with the touch screen, so if yours fails then you cannot use the TPMS or the ESC functions (if like me you did not have the buttons fitted).
Out of all the functions which are via the infotainment screen these two are the most important for the running of the car, this is WHY Bosch still supplies the ABS units with two dedicated pin outs for auxiliary stand alone buttons! Otherwise they could save loads of money by not making those extra two pin outs etc on the PCB & ECU coding! This also explains why the MK7 Golf was designed from day one with the ESC & TPMS buttons in the gearstick surround console. Just bean counters have removed them on most models!
I personally prefer to not have to rely on important functions like this for a touch screen, however with more & more new cars opting for a "clean" dash look & moving everything to the touchscreen, I fear that more cars will become undrivable if the main screen fails!!
Part 1 of 4
Special thanks to
Introduction
Research
