I think a lot of people are expecting this little device to make their car Rolls Royce quiet. That's not what it's for.
As I mentioned in the start of this how to guide...a lot rests on the amount of metalwork in your bodyshell, & the spring stiffness..& also I recon the wheel weight...& that's all besides the rear damper/top mount interference problem..which causes a knocking sound...
My car has the most metal work to resonate, has factory sports suspension, & lighter aftermarket wheels...plus I drive a lot with the radio off...
So I hear stuff...& I like things to be "right".....
The rear suspension still makes noises over bumps, potholes etc, ..BUT these are more appropriate to the size of bump/pothole, speed of car etc..
Now there is no longer any "after" noise, resonances etc...so the sound is now "thud"...instead of "thump, rattle"...
Yes on rough surfaces I still get a low/quiet rattle as you can hear the suspension flexing over the ripples in the road...but again its "input=output".....& not sounding as if half the rear suspension is worn out!
