How to retro-fit the 312mm front brakes to a Mk7 Golf
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
Thanks, any idea why the caliper mount bolts for the 288mm brakes have a different part number than the 312mm?
First page second post down by me...
Item No. 4:- N91 084 901, Hex head bolt (M14x55mm) for cast alloy hub
Item No. 4:- N90 948 802, Hex head bolt (M14x35mm) for cast iron hub,
the aluminum hub carrier is thicker where the bolts holes are to achieve the same strength as the cast iron version...:cool:
Armchair Racer
Florida
If I’m not changing the hub, do I need different size bolts?
I guess what I’m asking is are different size caliper mount bolts needed for the 312mm upgrade?
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
NO.....as the calliper bracket regardless if for 312mm or 288mm discs ..the thickness around the holes is the same...
so if you are just swapping the caliper carrier and /or caliper you retain your existing bolts...
its only if you swap the hub carrier from cast iron to alloy that you swap the bolts...
Armchair Racer
Florida
Awesome, thanks guys. Can’t wait to do this mod. Scored some used calipers/mounts/pads on eBay for $70 shipped (both sides).
If I install these used calipers which already have mounts and pads will I get a brake pad warning light?
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
if the pad warning light wire on the used pads is worn.yes you will..thats how it works....
Armchair Racer
Florida
Did this upgrade two weeks ago. The brakes feel exactly the same as before. No better, no worse. Even the pedal feel is virtually the same. These brakes work way better in my TTRS. I wonder if it’s because that car is so much lighter than my wagon or if it’s because of the different master cylinder?
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
Very strange...:confused:...
…..the 288mm setup & master cylinder is the same as the 312mm GTI/GTD setup only difference is the carrier & the disc ….& I felt a much more linear response afterwards as the 288mm setup was grabby...
Cuzoe
The TRW specs show the same for the Golf vs GTI/PP/R master cylinder (despite the different VAG part numbers, if I remember correctly the GTI part number ends in "B") but they are in fact different, as is the brake booster. I have upgraded brakes on my Golf TDI and bought the GTI master cylinder to have installed at the same time thinking it would be a direct swap, it was not.
I'm only talking NAR, haven't looked up any part numbers for ROW. But the gulf has a different set up from it's faster brethren, which all share the same part number. As I recall the GTI/PP/R share the same part numbers as the S3 as well.
Sent from my ONEPLUS A6013 using Tapatalk
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
In UK which has German built cars we have bigger rear discs as standard on all sub GTi cars as we all have the electronic parking brake (you now get this also)..
Here is the Master cylinder for MK7 Golf hatch for EU build.
Look at the column "data model"..these are the PR codes.....8V0 611 021, & 8V0 611 021 B, are for 1ZA, 1ZD, 1ZE, 1ZF, 1ZP.....This covers all basic cars & GTD, & 312MM DCC option so swapping a 288m to 312mm will work as from factory, as I did...
8V0 611 021 A is for the 312m GTI, & 340mm disc/60mm piston caliper & also which come with the vented rear discs....1LJ, 1LV, 1ZB,1LM
1ZF 276mm SILVER ZINC basic spec cars.
1ZE/1ZP 288MM SILVER ZINC
1ZA/ 1ZD 312MM GREY, GTD & DCC equipped cars which would otherwise have 288mm
1ZB/1LV 312 RED, GTI
1ZC/1ZG 312MM BLUE, GTE
1LJ RED, GTI PP, CLUBSPORT, CLUBSPORT S
1LM BLACK, R
tigeo
golfdave - did you change your coding in your brake control module to refect the change from 288mm to 312mm brakes? I found this:
Byte 4 in the brake control module should read 24 for vehicles with 288mm brakes and 34 for vehicles with 312mm brakes. To get there, you have to check bit 4 in addition to bits 2 and 5.
Not I use OBDEleven but VCDS of course will be the same.
anotero
SoCal
In for answers too. If so, do I need to change any coding after upgrading from non-PP GTI brakes to PP?
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
GODD FIND!!
Never even knew that existed?......interesting..mind you mine is a 2014/2015 build so may not have this...
..I have VCDS (unlimited VIN) & will be trying this out in the next couple of days as I have centre console apart for the DG superpin...& by removing the EPB & CC units I have loads of fault codes to clear..
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
VCDS says NO..
Nothing written in VCDS..so manually changed the bit from 24 (288mm) to 34 (312mm)...then VCDS threw a stupid "this module appears to be un-initialised" message, used stock importer coding & then it threw it all out saying "out of range".....bugger..
module all ok & back to previous ok...
Elwood
3-7-77
Long Beach, CA
VCDS says NO..
Same in my 2017 US market 1.8.
golfdave
Scotland (U.K.)
Ride
MK7 Golf GT Estate
All cleaned up and ready...used 312s off an Alltrack. Now to figure out rotors/pads.
I hope you remember which pin /slider is top as there are two different pins...on is all metal & the other has a plastic bush at the end...& use TRW grease on the sliders..NOTHING else..
