golfdave
- Scotland (U.K.)
- MK7 Golf GT Estate
Hi, yeah. But Octavia 3 1.4 tsi with torsion beam rear is equipped with 253 mm (10mm non ventilated) diameter discs at back. Golf and Octavia 3 1.8 tsi (and later 2.0) got both multilink rear with 272 mm discs (10mm non ventilated). Yeah sure it wont make big difference due the weight balance shift, but just thinking that is this so bolt-on fit for 1.4 ocu. Front is same with 288 mm discs and 57 mm pistons. But is that difference 253 vs 272 at rear starting to feel somehow, and are there more differences I should be aware of? Master cylinder?
Your Octavia will have a manual hand brake...those 272mm have electric hand brake in Europe on the Golf.....
Also if they only fitted one size/type to the torsion beam axle, & the bigger ones only to the Multi-link, the mounting points will be different for the brake caliper, so you may not be able to swap them over unless you also swap the suspension over..which is more difficult on the Octavia than on the Golf...
