golfdave
- Scotland (U.K.)
- Mk7 Golf GT Estate
drive2.com?
Doh!!...yes some good stuff on there....!!
drive2.com?
Oh, I'm jealous. There is no such OEM option in the US, even though we have states that get as cold as (or nearly as cold as) Sweden! I'd be all over that if it were offered in the US.
I've been meaning to ask this for a while: I got the aero tray without a rear grille. My oil temps usually hover around 104 degC on extended drives. Is that fine? I may make a few small holes in the aero tray around where the sump is.
My car has the skid tray with the duct (1.4l 150hp 6-speed). Average highway oil temps are in the mid-90sC (Swedish winter) / high-90sC (Swedish summer). I have yet to see higher than 103C in over 71000km.
104C is ok for hot trips....when it goes over 110C & holds... thats when you need to think about more holes...or the GTE aero tray
Guys, I think it's important to recognize different motors here... it's perfectly normal for the US/Canadian market 1.8TSI and 2.0TSI (our only motor options until 2019 when they replaced the 1.8TSI with the 1.4TSI in non-GTI and non-4-motion models) to reach 107C regardless of weather. My 1.8TSI used to hover around 103C before adding the aero tray (with ducts) + front exhaust tunnel cover, it now has gone up to a max of 107C (on the highway pullign a trailer through mountainous areas) but usually hovers around 104C. This is perfectly acceptable with full synthetic oil. Most of the racing forums and the more techie oil forums (see bobistheoilguy.com for example) all share the consensus that full synth oil can survive sustained 115C temps with no ill effects.
Personally, I like seeing my oil reach 107C for long highway runs because so much of my driving is from cold starts, going 1-2 miles around town on errands, which is the WORST thing for oil since moisture develops inside the bloc and mixes with the oil. Getting the oil above 100C for extended intervals likely rids any moisture building in the oil.
I grew up in the San Joaquin valley and got my degree at Loma Linda University. I managed to get back to California 3x during 2019 and experienced at least one >100F day while we were there in July. That a good job of reminding me why I stayed in school to get out of the construction business!I live in Southern California, in a desert. It's a tad bit warmer here than in Sweden.
Back to the subject at hand - I was just providing a reference point, and I certainly didn't mean to imply that oil temps over 100C are bad. Quite the contrary! I would rather that the engine in my car was running 100-105C when fully operational year-round, to regularly vaporize any condensation or other water that might make its way into the lubrication system.
Hi Golfdave, and thank you for the DIY manuals. I have installed the Passat cover and dynamic damper to my G7 2.0tdi estate and now I want to retro-fit the rear exhaust tunnel cover.
I have got multilink versions 5Q0825206C and 5Q0825206M (they are almost same). Problem is that they both seem to be shorter than is necessary (3-5cm) and because of that I am not able to install them properly. Any idea what is wrong? Is there any longer variant? Thanks.
