Chillout
- the Netherlands
- SEAT Leon FR ST
Part VI
Rear lower arm stone guard/aerodynamic trim for Twist-Beam Rear Suspension.
http://www.partsbase.org/vw/golf-var...hock-absorber/
Item No. 17:- 5Q0 501 559 "C" or "D", Stone chip guard for under side of trailing arm left side.Item No. 17:- 5Q0 501 560 "C" or "D", Stone chip guard for underside of trailing right side.Item No. 18:- 5Q0 501 561, Stone chip guard for top side of trailing arm left side.Item No. 18:- 5Q0 501 562, Stone chip guard for top side of trailing arm right side.Item No. ??:- 8E0 825 267, 8mm spreader rivet. Unknown quantity required.
These items I have not actually seen or fitted, but they appear on ETKA for the MK7 Golf with the Twist-beam rear suspension, so should fit & cover the trailing arm part of the rear twist beam.
I can confirm: these fit. However, on my car, it wasn't a perfect fit, because part 3 and 16 got in the way. 2 spreader rivets were needed, I added an additional cable tie for increased security. I ordered 5Q0501559C and 5Q0501560D, both of which had this same issue, so I had to trim the notches at the part that clicks into the spring seat.
Pics of it installed on my Leon ST (which is basically the same as Golf Variant with torsion bar rear suspension):
In this picture, you can also see the Golf 8 axle beam cover (5WA501715A ) installed. This was a perfect fit, and it lines up nicely with the lower arm covers.
