How to retro-fit a bigger capacity battery to a Mk7 Golf
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Thanks for the great write up here. I appreciate you taking the time, as it really help me, and others out.
I didn't go to the trouble of getting a bigger battery, but I did switch from a stock battery to an AGM with more CCA. I invested in the ODBeleven so I could update the Battery fields. Your write was a HUGE help with that.
Glad you got it sorted!!..& AGM even for the same case size has more amps & is just way better in cold temps & way safer in a crash...!!
rking3
Houston
2016GTI; 2020Tiguan
Hey golfdave
Will the AP7610 work for the necessary coding and registration?
Or would I need the VD700?
Thanks
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Hey golfdave
Thanks
No idea I don't use them...& don't I know if they do coding.....& there is no need to "register" anything its not like component protection...
rking3
Houston
2016GTI; 2020Tiguan
Thanks
Are you just using a cable to your PC?
I am not familiar with VCDS, but when I google it, those options come up for coding
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Thanks
I use the latest VCDS (unlimited VIN) with the latest bought cable connected to a laptop ..(cable which cost me over £400)..I do coding for other peoples cars.....
the free version of VCDS is a very old program & doesn't work properly with the newer CAN modules as the MK7 Golf etc..
StorableComa
Long Beach, USA
17 GSW S
If you need something a little more budget friendly, look up ODBEleven (ODB11). It's a similar setup that allows you to make coding changes to your vehicle and check other items. I haven't used it personally, but I believe it's a bit cheaper depending on the functions you need.
rking3
Houston
2016GTI; 2020Tiguan
Yes I've heard about that and the pro version
I think the two I referenced above, the AP7610 and the VD700 should perform the same functions
But was asking for a double check
KevinC
'19 Golf R, '08 Z4MC
I'd skip Optima - their quality went downhill about a decade ago when they were bought out and production moved out of the USA. Just get the best Group 48 AGM battery you can find at the best price. I went with a Duracell from Batteries+ because they have a 4-year full replacement warranty, which is a good thing to have in Arizona. But just about any equivalent battery will perform just as well.
rking3
Houston
2016GTI; 2020Tiguan
Golfdave! Huge shout-out and thanks to you
Install is tight but obviously doable
Coding can be done on the vd700 but wasn't as simple as advertised
My choice was between 3 batteries
https://www.samsclub.com/p/auto-group-48-h6-agm-36-mo-free/prod9510085
https://www.autozone.com/ignition-t...gm-group-size-48-760-cca/319460_1363977_25698
https://shop.advanceautoparts.com/p...ttery-group-size-h6-760-cca-h6-agm/10210829-P
Decided on the diehard
I went through 2 factory batteries in less than 4 years. No way I was replacing it with the same OEM corner cutting battery.
ervybaby
YUL
Golf2015 Mk7 TSi 1.8
Not sure if it was mentioned in this thread but do Golf Mk7 TSi cars with no 'Start-Stop' have an internal BCM and/or need to reprogram the computer when changing the battery via scanner tool? Tnx.
