[HOW TO PATCH] MIB2/MST2 Delphi HeadUnit (MST2_VW_xxxxxD) patch [FEC/SWAP/CID/CP]Android Auto,CarPlay and many more
ash9949
Poland
golf 7
i tried using this as of late, i couldn't get it to remove CP or do any other patches
your supposed to put the patch .sh in the root of the card right and name it to delphi.sh
i did this,.....reading sd card....
waits 5 seconds then reboots
but nothing changed on the deck
any ideas ?
thanks
Format the SD card like mentioned method and copy all the contents in folder to root of the SD card and later follow the instructions in pdf file which also included in folder which is inside zip file
And for first make sure you have Delphi unit which also mentioned how to check that
Or simply press and hold menu button and take a picture and post here with system info of your unit
gti-boy88
Canada
2015 VW GTI
UPDATE 01.02.2023
Delphi MST2 SD Activator by Congo & Duke
this is new AIO(All in One) package patch for delphi units
its very easy than unlocking a bootloader of android
#Needed​
  1. Quality SD card, 4GB or more (how to check SD card),
  2. MST2 Delphi unit,
InfoWarningTip
Press and hold MENU button for 3 seconds, go to Software Update/Versions, find SW Train and confirm that it starts with MST2 and ends with D. For example: MST2_EU_VW_P0891D.
  1. Activator from here: https://mega.nz/folder/J0QknTKQ#Goqv8h29q5BrxqS7wIbQ1Q,
  2. Diagnostic tool for post-activation coding and adaptation chages (if required).
#Supported firmwares​
Almost all firmwares (Audi and VW, all regions) and series like below:
  • MST2_xx_xx_x02xxD
  • MST2_xx_xx_x06xxD
  • MST2_xx_xx_x08xxD
  • MST2_xx_xx_x9xxxD
Tested and confirmed on: 220D, 231D, 628D, 635D, 642D, 9122D STD2Nav, 867D, 876D, 890D, 891D, 879D.
#Prepare SD card​
  1. Format an SD card with FAT32 file system,
  2. Make sure to set the Allocation unit size to the smallest option available (example 4096B),
  3. Extract downloaded activator package,
  4. Copy content of the activator package to the SD card.
#Installation​
  1. Turn the ignition on,
  2. Empty SD card ports in the main unit,
  3. Place the SD card in the SD1 port,
  4. Press and hold MENU button for 3 seconds to enter the Service Mode,
  5. Select Software update/versions,
  6. Select Update → SD card → MST2 Activator by Congo and Duke → Start → Next,
  7. Wait. During the activation will reboot 2 times,
  8. When the process is done you will see summary screen. Press Back in the upper-right corner,
  9. When you see Version back documentation screen, press Cancel,
  10. Wait for the final reboot of the unit.
  11. Review changes.
#Post-activation coding and adaptation (if required)​
#CarPlay, AndroidAuto​
5F → Adaptation → vehicle configuration → Apple DIO → enable
5F → Adaptation → vehicle configuration → Google GAL → enable
#B201A fault​
After installation you will have B201A fault code stored in module 0x5F. Check how to clear B201A code.
USE AT YOUR OWN RISK!
What does this patch exactly do? And does it work?
sem1309
Danmark
VW Passat B8
UPDATE 01.02.2023
#Needed​
InfoWarningTip
  • MST2_xx_xx_x02xxD
  • MST2_xx_xx_x06xxD
  • MST2_xx_xx_x08xxD
  • MST2_xx_xx_x9xxxD
#Prepare SD card​
#Installation​
  11. Review changes.
#B201A fault​
USE AT YOUR OWNA
After update I had a problem. Head up display did not work. You just need to press a physical button. Everything else works great. Thank you !!!!
VW Passat B8 MST2_EU_VW_P0639D
MK0777
UK
Golf 7
Which software version you have on your car ?
I don't know because I'm wondering which one to buy to unlock it easily. I haven't bought a unit yet. Tell me because I don't know if I understand correctly. Old method unlock delphi unit is use the usb-rj45 adapter? And now we need only sd card?
sem1309
Danmark
VW Passat B8
Yes, old method (d link dub e100) you can use for all Delphi units, for MTS2 Delphi units you can use SD cards method.
If you need d link dub e100 I can send to you. Where you from?
MK0777
UK
Golf 7
I think the shipping costs will be more than buying the USB D-link. I can buy it for 30€ in my country. Does this patch have "cp off" implemented?
