[HOW TO PATCH] MIB2/MST2 Delphi HeadUnit (MST2_VW_xxxxxD) patch [FEC/SWAP/CID/CP]Android Auto,CarPlay and many more
ash9949
Poland
golf 7
UPDATE 01.02.2023
Delphi MST2 SD Activator by Congo & Duke
this is new AIO(All in One) package patch for delphi units
its very easy than unlocking a bootloader of android
#Needed​
  1. Quality SD card, 4GB or more (how to check SD card),
  2. MST2 Delphi unit,
InfoWarningTip
Press and hold MENU button for 3 seconds, go to Software Update/Versions, find SW Train and confirm that it starts with MST2 and ends with D. For example: MST2_EU_VW_P0891D.
  1. Activator from here: https://mega.nz/folder/J0QknTKQ#Goqv8h29q5BrxqS7wIbQ1Q,
  2. Diagnostic tool for post-activation coding and adaptation chages (if required).
#Supported firmwares​
Almost all firmwares (Audi and VW, all regions) and series like below:
  • MST2_xx_xx_x02xxD
  • MST2_xx_xx_x06xxD
  • MST2_xx_xx_x08xxD
  • MST2_xx_xx_x9xxxD
Tested and confirmed on: 220D, 231D, 628D, 635D, 642D, 9122D STD2Nav, 867D, 876D, 890D, 891D, 879D.
#Prepare SD card​
  1. Format an SD card with FAT32 file system,
  2. Make sure to set the Allocation unit size to the smallest option available (example 4096B),
  3. Extract downloaded activator package,
  4. Copy content of the activator package to the SD card.
#Installation​
  1. Turn the ignition on,
  2. Empty SD card ports in the main unit,
  3. Place the SD card in the SD1 port,
  4. Press and hold MENU button for 3 seconds to enter the Service Mode,
  5. Select Software update/versions,
  6. Select Update → SD card → MST2 Activator by Congo and Duke → Start → Next,
  7. Wait. During the activation will reboot 2 times,
  8. When the process is done you will see summary screen. Press Back in the upper-right corner,
  9. When you see Version back documentation screen, press Cancel,
  10. Wait for the final reboot of the unit.
  11. Review changes.
#Post-activation coding and adaptation (if required)​
#CarPlay, AndroidAuto​
5F → Adaptation → vehicle configuration → Apple DIO → enable
5F → Adaptation → vehicle configuration → Google GAL → enable
#B201A fault​
After installation you will have B201A fault code stored in module 0x5F. Check how to clear B201A code.
USE AT YOUR OWN RISK!
ash9949
Poland
golf 7
Most of topic image not displaying, please fix it so we can see steps clearly
Thanks
hi, you can still follow the source link on top, which has pictures, i need some time to edit and upload pictures manually one by one, its alot of work
VQVW
Oregon
2018 Alltrack SE 6MT
hare your knowledge with fellow VAG-Heads to collectively build on the newest hacks or solutions.
At the moment we are mostly focused on MIB solutions but this should be considered an open board to share knowledge about our favourite VAG cars.
To discuss anything on this board get in touch on either:
This is a helpful resource! Here's a question: I just want to update my firmware to the latest. I don't want or need any patches or modifications. I'm just trying to figure out what is the latest US firmware for my 2018 Alltrack.
Here's what I have currently: MST2_US_VW_P9120D for software train version, software 0842.
I am looking at mibsolution.one for updates; I don't see a MU879 version for US---is MU870 the latest for US, or where would I find the latest?
ash9949
Poland
golf 7
https://mibsolution.one/#/1/9/MST2 - DELPHI/Firmware/VW/US
password : guest
ash9949
Poland
golf 7
geokilla
Toronto, Ontario, Canada
2018 VW GTI DSG
Thanks. Can you confirm that 0867 is the most recent US firmware from VW?
0879 is the most recent one. I got it from the dealer a few months ago.
Installed software train version: MST2_US_VW_P0879D
Installed software MU version: 0879
Part number: 3Q0035876B
Software version: H29.319.115_STD2NAV_NAR
Model: GuideModel_29.319.30
Software Base: H29.319.115-201909261449
ash9949
Poland
golf 7
Can you please post a link for download
ash9949
Poland
golf 7
Installed software train version: MST2_US_VW_ZR_P0245T
Installed software MU version: 0245
Part number: 3Q0035878
This would be a non-nav unit that has two SD card slots, which I guess doesnt match whats said in the second link. Might be because the original 5F unit that came with my car died within the first week and was replaced.
Does this head unit have 2 Sd card slots ?
