Beats me, - my MST2_US got bricked.. so i have a dead unit.
I tried a couple different firmwares.. pre-hacked and otherwise, but I could never get it to work.
I thought I had it once, but .. when i was copying over the patched files.. something didn't go.. and now it's bricked.![]()
ah - yes, the bricked unit is sitting in a box, taunting me..You still have the bricked unit? They have a recovery firmware if you jump 2 pins while it powers on. Bricked mine like 3 times while trying to upload a custom file to it lol
What I understood , in fecs you must leave your support numbers, and remove vin and vcrn file, if want add new body must add new fec number end edit VIN and VCRN files with yours.Hi Guys,
I have VW Tiguan 2018 and (as many people here) I wanted to unlock Apple CarPlay and to remove the SD Card CID lock.
This is my MIB2 Delphi unit:
- MST2_EU_VW_P0879D
- 3Q0035864C
- it was not patched ever, just original firmware
Before I will try to patch my MST2 Delphi unit, I just wanted to ask you (and confirm) few questions I have:
1) This Delphi MST2 SD Activator do NOT require "developer green menu" to be activated - I just need SD card where I copy just the patch?
2) On mega.nz I see 2 zip files with activator (can you please confirm which should I use and what is the different between them?):
- MST2_Activator_Made_By_Congo_and_Duke_pre_v2.1_VIN_Bug.zip
- MST2_Activator_Made_By_Congo_and_Duke_v2_Lazarus_Raised_from_the_Dead.zip
3) The link about #B201A code (how to clear it) doesn't work:
- can you please update this information?
- can I delete this fault code with OBD11 standard edition (without PRO license)? or do I need VCDS for example or OBD11 PRO?
5) My MST2 unit shows the following codes:
- installed:
00030000
00040100
00050000
00060100
00060200
00060400
09400008
- supported
00030000
00040100
00050000
00060100
00060200
00060300
00060400
00060800
00060900
00060b00
00070200
00070400
09400003
The question is which codes should I add/remove to/from "addFecs.txt" file to be closest to my original config and have unlocked Apple CarPlay and SD card CID lock?
If I modify "addFecs.txt" file - should I also modify VIN and VCRN files?
Cheers!
http://mib-helper.com/index.php?train=MST2_EU_VW_P0867D#detailsHello, I am interested in upgrading my system. i have this version
MST2_EU_VW_P0867D
SW version 0867. What is the latest version I can install? it's advisable? I'm afraid of losing carplay. add any new features? Thanksss
http://mib-helper.com/index.php?train=MST2_EU_VW_P0628D#detailsI have VW Tiguan 2016
- MST2_EU_VW_P0628D
- 3Q0 035 819B
- installed:
00030000
00050000
- supported
00030000
00040100
00050000
00060100
00060200
00070400
can I unlock carplay? how can I do ? What is the latest version I can install?
I cannot figure it out to save my lifeOmg ? it actually worked. I now have CarPlay!!
Exactly the same in my case. Any help would be appreciated.Have applied the patch but CP still stays on screen.
MST2_US_VW_P0890D
0890
3Q0035844B
