0891 version will be enough - easier to upgrade (directly via SD card).Hi Team, quick question as i'm new in this area.
I've the P9122D train sw (842). Telnet is not accessible on that version. Should i update with the version MST2_EU_VW_P0879D_MU0879-wTelnet that i found on mibsolution ?
thanks in advance for your help
Do you know what the latest 08xx U.S. version available is with telnet? My replacement MIB2 Delphi came out of a Tiguan and is running 0867, unclear if it can be upgraded past that or not?0891 version will be enough - easier to upgrade (directly via SD card).
Similar issue, after the MIB swap I've got static U105400 (Information electronics control module 1, no communication.) Won't clear unfortunately in case anyone has any tips on how to solve.Welcome to All
As instructed, I have unlocked APPConnect services and voice control in my MIB2 Delphi.
Previously I had to downgrade the firmware version to 0891D.
After the operation I removed the unnecessary .fec codes and everything worked correctly.
Only the error problem remained: OBD11 shows a static error U111100. Possible to remove but appears again.
How to deal with this? I have no idea at all.
I found version no 0870, but with earlier date (0870 - 31 mar. 2021, 0867 - 30 sept. 2021)Do you know what the latest 08xx U.S. version available is with telnet? My replacement MIB2 Delphi came out of a Tiguan and is running 0867, unclear if it can be upgraded past that or not?
I have purchased a MIB2 .. with MST2_US_VW_P0867D_STD_PLUS which I'm trying to fit to my 2015 Golf. Unfortunately, when I connect the USB ethernet adapter, I do not get an ip address.
It appears that IP is never displayed in the Green Engineering Menu.
I've tried to separate ASIX88772 units, and I have adjusted the PID/VID via ethtool to try be Dlink DUB-E100 rev B1, C1, D1 (I followed instructions here:) . and none of the versions of the D-Link DUB-E100 VID/PID seem to work.
Component protection is active - is that preventing ethernet access?
Should I try a AX88179 ? Is there some other trouble shooting step I should take?
I could try upgdating the firmware to version 0870, but I have not taken that step yet.
Should I try a different VID/PID?
such as:
SMSC9500 (0x0424, 0x9500)
Germaneers LAN9514 (0x2721, 0xec00)
Cinterion AH6A 3G (0x1e2d, 0x0055)
Cinterion ALS1/ALS6 (0x1e2d, 0x0060)
Thank you for any suggestions.
Beats me, - my MST2_US got bricked.. so i have a dead unit.so how did you get on with this MST2_US_VW_P0867D_STD_PLUS ??
i have a MST2_EU_VW_P0867D_STD
and im hell bent on hacking it
i will post all my findings here in this forum too
damn thats bummerBeats me, - my MST2_US got bricked.. so i have a dead unit.
I tried a couple different firmwares.. pre-hacked and otherwise, but I could never get it to work.
I thought I had it once, but .. when i was copying over the patched files.. something didn't go.. and now it's bricked.
damn thats bummer
im trying to grab the patched from the OP links
but the links are dead and i cannot grab the files :S
dave
i tried using this as of late, i couldn't get it to remove CP or do any other patchestry new aio patch its very much easy pezzy, lemon squezzy
