[HOW TO PATCH Component Protection] MIB2/MST2 Delphi HeadUnit (MST2_VW_xxxxxD) patch [FEC/SWAP/CID/CP]Android Auto,CarPlay and many more
Benihana
Socal
HI Castiel,
Yes, correct as you listed. Load version 3.0 onto the SD card and proceed. I don't think the ignition will shut-off during the update I wouldn't worry about that. The activator might also unlock more features than just Android Auto. Good luck!
Castiel
Hungary
VW eGolf
HI Castiel,
Hi!
Thank you the answer!
One more question what is not clear for me.
In common folder there is two dummy files (VCRN and VIN)
Just let them in this form, or should I change them to txt with my VCRN and VIN datas?! If yes, then just the file name should be changed or it must conatin the datas too?!
Thanks a lot!
Benihana
Socal
Hi!
Thanks a lot!
I would leave them as is. I didn't touch mine and it all worked out.
Sztandar18
Poland
Golf 7
Hi.
I have launched the Congo and Duke patch on the unit
3Q0035819B
SW Train MST2_EU_VW_P0628D
Unfortunately I do not see the App-Connect option in the MENU. What additional steps do I need to take to launch Android auto on this unit?
Castiel
Hungary
VW eGolf
Hi.
3Q0035819B
Hi!
Have you checked which functions are available?
Menu button long push --> Function enabling codes--> supported FECs and installed FECs menues.
You should check the codes, use google, "FEC/SWAP codes lists" or something simillar. If you identified your codes and there is no android auto among them then your MIB does not support the function.
If it supports then sorry I do not have more power in this topic :D
I have done it last week and worked well ( not the sam train code)
codeskilla
Arkansas
Mk7 R
Okay, trying to do this on my 2015 R. Current firmware is MST2_US_VW_P0504D
I tried running the congo and duke activator, put it all on a 64gb SD formatted to FAT32. Went through the update and followed congo and duke write up, component protection is still active. All FEC codes seemed to work as I have apple car play, sport monitor, think blue, etc. Just still in component protection
Update. I’ve figured out that I need to run the Congo and duke activator first, then I need to run a patch to remove CP.
Here’s my issue. I add the Delphi.sh file to my SD card along with the appropriate delphibin patch for my software train. So the only things on my SD card are the
Delphi.sh
delphibin.ifs
Test.txt
Once I put the sd card in after writing the patch files to it I reboot the radio and nothing happens? From what I understand the activator is supposed to run these patches automatically? Or is there something else I should be doing.
Latron
Master of oil top off
Dallas, TX
2015 GTI DSG
OK, I am doing this with a new radio. I have the correct delphibin.ifs but where can I get the Delphi.sh file? I cannot seem to find it. I have already run the congo and duke and it is working, now I just need to code the CP out.
Edit: Never mind I found it on my computer. Now i just need to figure out if my unit is a Plus unit. After running the activator the info is this.
Activator for MST2 Scale made by Congo & Duke
SW rev: 1769
Device type: STD2Plus
Brand: VW
Device region: NAR
FW ver: MST2_US_VW_P0867D
FW MU ver: 0867
HW: 722
FAZIT: 8VV-DDM15.05.1800011422
Patch for /tmp/developer successful. Check ReadMe.txt how to use it.
Metainfo patch successful.
SWaP patch applied successful.
EL list created successfully.
Backup of current SWaP codes done!
Adding 00030000 to FEC list.
Adding 00040100 to FEC list.
Adding 00050000 to FEC list.
Adding 00060100 to FEC list.
Adding 00060200 to FEC list.
Adding 00060300 to FEC list.
Adding 00060400 to FEC list.
Adding 00060800 to FEC list.
Adding 00060900 to FEC list.
Adding 00070100 to FEC list.
Adding 00070200 to FEC list.
Adding 00070400 to FEC list.
Adding 09400008 to FEC list.
Adding 09410008 to FEC list.
Adding 094D0008 to FEC list.
Adding 094200ee to FEC list.
Found FECs in pg dir, will use VIN and VCRN from them.
Parse 1107
Would i use the this one?
dubik3e
PL
Golf 7
Sorry, but reading all these threads about MIB2 CP off, carplay, mibsolution, mibwiki and others, I had one big mess in my head.
Oryginaly I had MIB1 which I'm trying to retrofit with mib2 delphi mstd2 nav 3Q0035846B. I would have problem with CP and I would like to have AndroidAUTO.
Is "MST2_Activator_Made_By_Congo_and_Duke_v3.0_Unbroken" taking off CP and unlocking Android auto at the same time? I'm pretty sure not. Than is there any other option to remove CP than by Putty,ethernetcable and USB port? By scripts? If yes, it looks like not everyone have luck and made it work.
nuklear10
France
GTI ABT DARK 2015
SW rev: 1769
Brand: VW
Device region: NAR
FW MU ver: 0867
HW: 722
Parse 1107
Hello please can you send me your Delphibin.ifs and swap file ?
i think i flash (script with SD) the wrong file, for my unit MST2 Delphi (MST2Plus), for remove CP, and khow bootloop :(
and please can you tell me what you put in text's file ?
thank you in adavance
lucianpistol
Bucharest
Vw Golf Sportsvan
Hi guys,
Noob here. Just bought a Golf Sportsvan and I was wondering if anyone could help me with the latest version for the framework so I can update it and see If I gain more functions on my multimedia unit:
Current details are:
Part no: 3Q0035824B
Hardware: 710
Software: 0751
Codec media: 1.2.0
Many many thanks in advance,
Lucian
anton.desar
Mexico
Golf Variant 2017
Hi, could you help me update?
I have not found any information or firmware.
I hope you can help me please
The info is
MST2_US_VW_P0216D
MU 0597
PART NUMBER 3Q0035844
[EDITED]
Resolved with help from the guys over on the Discord group. It was quite simple in the end, seems I had a corrupt MicroSD card and that's all.
Key takeaways
1. Ensure you have a good memory card. I borrowed one from my dashcam, but I think it wasn't geared for such heavy use and probably broke down quickly. Maybe better to use an SD card (and not MicroSD with adaptor like I did)
2. Use the original Duke and Congo activator file. There's a few modified versions out there.
3. No need to update your VIN or VCRN. The dummy VIN and VCRN will do the trick
4. Don't extract a the activator .7z file extension through Windows Explorer. Use 7zip instead.
5. MK7 community rocks!!
mcquaim
Monaghan
2016 VW Golf TDI 2.0
Hi guys,
If I’m upgrading from an MIB1 unit to an MIB2 unit and using this Congo & Duke patch method will it also remove CP or will I have to also get some other method to remove CP?
Cheers,
Mac
