edward@becautoparts.com
- Vancouver, BC
So you purchased a set of our HID Headlights and a Morimoto HID kit. Now, how does all the wiring go together.
This is what you get:
- Morimoto XB35 or XB55 Ballasts (2x)
- D2H HID bulbs (2x)
- Canbus H7 Harness adapter (2x)
- Morimoto XB Igniters (2x)
On the canbus relay, disconnect the H7 harness adapter (the shorter wire) you will not need it.
When wired, it should look like this:
The orange and black spade connectors connect to the corresponding connectors inside of the headlights. These give the signal and power to the HID ballasts to turn on.
Also notice the position of the bulb, the bulb must be in this position, or the beam pattern will look "weird", it will be all blotchy, rather than a sharp cut off.
When installing, notice the position of the connectors, and the pins in the ballasts, they must be installed this way.
As well, be careful and do not bend any of the pins in the ballast when installing the connectors.
When complete, you can mount the ballast to the side of the headlight or underneath with the use of Velcro tape or screws.
