emichel6888
- TX
Since switching to Ferodo 2500 break pads I experienced a LOT of low speed brake squeal. I love the pad performance, it is good street light track use pad but the brake squeal was killing it for me. I tried everything, cleaning and lubricating the brakes, those sticky products they tell you to apply to the pad backing, none of that stuff works. At least not with an aggressive street/track pad.
I was somewhat desperate to fix this issue and came across this brake squeal treatment product that you actually apply to the pad and rotor friction surface with a spray can! The reviews were somewhat mixed and to say that I was highly skeptical would be an understatement, as it went against everything I knew about brake maintenance. However, like I said I was desperate and had plans to upgrade my pads and rotors soon and it was at my local auto part store for $8 so I figured what the hell, give it a shot.
You have to remove the rotors and apply it to both inner and outer rotor surface, and it goes on and looks like silver spray paint. Well I did it, put it all back together and I’ll be dammed, it completely eliminated my brake squeal! You have to do a few low speed stops to burn it off the pad surface, but after that it does not affect brake performance at all.
I have been holding off talking about this for fear that the squeal would just come back after a few hundred miles. I had it on the stock caliper/rotor with DS2500 pads for about 3-4 weeks and around 1500 miles and never heard even a hint of brake squeal, not once.
Then I upgraded to the Macan/Brembo calipers with ECS slotted rotors and decided to go with the Ferodo DS2500 pads again, and of course I applied this product to the new rotors, and just like the stock setup not even a hint of brake squeal at all. So now, it has been about four months and about 5000 miles with some hard braking and even a few track sessions, and still no squeals at all. Will it last the life of the pad/rotor? I don’t know but so far I am thrilled with this product!
Even if it does require a reapplication at some point, I am okay with that. I keep thinking at some point… but so far not a hint of squeal. I have been meaning to post about this and recently saw a few folks talking about brake squeal with this particular pad so… Anyway, if you have been suffering from brake squeal try this:
I used Gunk because that is what they had at my local auto part store, but CRC also makes a similar product and from what I can tell they are the same. You can also find both online:
https://www.amazon.com/CRC-05080-Sq...000M8H5M6/ref=cm_cr_arp_d_product_top?ie=UTF8
https://www.amazon.com/Gunk-M725-Squeal-Medic-Treatment/dp/B000ABIDBC/ref=sr_1_1?dchild=1&gclid=CjwKCAjwyo36BRAXEiwA24CwGTn9pKG99Ut0iV4YHZQOntgwJrP8RhApoEWWvdDSEnEALiRP59o1ghoCqNoQAvD_BwE&hvadid=267895229712&hvdev=c&hvlocphy=9027222&hvnetw=g&hvqmt=e&hvrand=16668101561508438122&hvtargid=kwd-456831355325&hydadcr=6401_9585563&keywords=gunk+brake+squeal+treatment&qid=1598293204&sr=8-1&tag=googhydr-20&th=1
Product description
Gunk Squeal Medic Brake Squeal & Squeak Cure stops brake squeals and squeaks before they start. It is applicable for all disc, drum, and ABS brake systems. No drying time required and is waterproof. Helps prevent oxidation of drums and rotors as well as rust and seizure of lug nuts and threads. Use on new or existing systems. It is safety tested by an independent laboratory to ensure safe braking after use.
Metallic formula fills grooves in friction surfaces for smoother braking
Spray on rotors and drums on every brake job.
Prevents brake noise
For use on disc, drum and ABS systems
It says it fills in groves in the friction surface but from what I can see not on the overall friction surface because that is quickly burned and scraped off. What it does is fill in variations on the edges where the pad and rotor meet, which makes sense when you consider the most likely source of vibration when you lightly apply the brakes. Here are some examples of both rotors I have used this on where you can see what I am talking about:
This stuff is literally like silver spray paint, so you will want to cover or tape off anywhere you don’t want that to get on. You do not have to let it dry but this stuff takes a very long time to dry at room temperature. I sprayed the ECS rotors and let them sit for two days, and even then if you touch them hard you will still get some on your hands. It seems like it takes the high heat of brake friction to really cure this stuff, so if you are just spraying and immediately reassembling the brakes you need to treat it like wet paint.
The instructions say to spray the rotors but I saw a video where they also sprayed the pads as well. The first time I just did the rotors and it worked fine, the second time I did both. I don’t think spraying the pads is necessary or even does much, but it did not hurt anything either.
The first time I used this stuff I just did the fronts, and then found the backs were still squealing, so you really need to do all four.
If you look for information on this stuff there isn’t a lot out there which really surprises me because this is the only brake squeal product that has ever really worked for me. Honestly I don’t know why more folks aren’t talking about it, or why the reviews are somewhat mixed. Possibly some folks have other brake squeal causes, or were too lazy to remove the rotors and apply to both sides and just sprayed the outside, who knows?
It seems this stuff has been around for years, why is it not more well known or popular I have no idea, because this stuff is frigin awesome.
Product description
