Gnasher
- Lincoln, UK
Didn't really know where to put this, so it's here.
Usual 'how to' rules apply - this is just a guide. If you are at all unsure of what you are doing, get it done professionally. The author nor the website provider is in any way responsible if you break your car following this guide.
Here goes - I'm doing it from memory so there might be a few things forgotten but I'm sure you'll get the idea...
1. First you need to take the grille off, this is simply two screws - one at either end on top of the grille and it lifts out with a bit of a tug.
2. Once that is off, you need to remove the black metal strips that go along the top of the headlights, there are three bolts on each, one near the wing and two near the grille...
3. Next it's worth popping the outer ends of the front bumper off. Three screws down inside the wheelarch on each side (one is tucked up where it joins the wing) and it pops off. This does need a fairly hefty tug so be careful!
Once this is off, you will see a silver dome headed bolt behind it (it's where the metal rimmed hole is in the photo)...
4. Next is the retaining bolts for the headlight. One is here near the grille...
...and there is another one nearer the wing (which you only need to loosen a couple of turns)...
5. Not 100% whether this is needed or not, however I did it and it helped. You need to remove the 3 bolts that hold the bumper to the rest of the car. These are in a line on what would have been the lower edge of the grille. This will allow a bit of movement in the top of the bumper to remove the headlight (no photos though).
6. Remove the plug going into the back of the headlight shown in the above photo. You can see the clip you need to press in on the side of it.
7. The headlight should now just pull forward and up over the bumper. Be careful, there is the ballast etc bolted to the bottom of it and these may scratch the bumper if you are too heavy handed.
8. Once removed, place it down so you can see the back of it and remove the five screws to remove the cover (screws are already removed in the photo...
9. Once the cover is off, you will need to remove the bulb (the back of it is the square metal box)...
You cannot remove the connector until the bulb is half out, so you need to turn the black plastic lever(s) that are around the bulb and it should then just pull out. Get it out so the connector can clear the housing, remove the connector and then the bulb will come out all the way.
Installation is the reverse of removal!
Here's a photo of the difference in colour temperature between standard (4300K) and the one's I got (6000K)...
Light output (colour wise) seems a perfect match to the fogs, however (and this might be because of the cheap bulbs I used or the fact that as you go higher in colour temp, the light output drops) there is very slightly less light output, but they are still very good headlights!
