Faceman
- Long Island
- '17 GSW 4Mo
I have a IS38 on a 1.8 GSW with AWE downpipe and all my readiness monitors are
Didn't know APR had readiness with a DP in IS38. Last I heard from them was you have to swap to a stock DP due to their tunes ignoring the CEL from the O2 monitor. Are you using their Non-straight/test pipe DP file? Be curious as to what your VCDS readiness numbers are.I have a IS38 on a 1.8 GSW with AWE downpipe and all my readiness monitors are![]()
Swapping the DP to stock would not be an issue, the turbo swap is more of a hassle though. If everything was stock except for the turbo (IS12 to IS20) that's what I'm curious about. For CA people I'm not sure I can get an answer from someone with experience because 2015 cars don't need smog till 2021, so any speculation in the meantime? Just genuinely curious because like someone else said, the turbos look nearly identical, and if I have a stock tune I wouldn't expect the emissions to be worse because it's still should be pushing light boost?Biggest issue would be the ODB2 hook up and readiness with the tune. They don't do sniffer smog anymore on newer cars in CA, it's a visual inspection and a readiness check. Currently I think APR has one on the 1.8T for an IS20 swap using the GTI DP, but I don't believe I've read of any IS32 stock DP tunes that will pass readiness on the GTI or 1.8T
Turbo if a OEM version might be okay, DP is questionable as I believe they look for CARB numbers on the DP. Not completely sure on that, with the heatshield in the way and a lazy tech you could get away.
APR so far is the only tuner i've read with an OTS turbo swap tune with stock DP that retains readiness. They have an IS20 with stock GTI DP file that retains readiness like a Stage 1 file would - I believe, could be wrong. All others, at least for the 1.8T, seem to be with a aftermarket DP on their turbo swap. This normally disables the O2 sensor CEL you'd get for the modified/missing Cats and higher flow.Swapping the DP to stock would not be an issue, the turbo swap is more of a hassle though. If everything was stock except for the turbo (IS12 to IS20) that's what I'm curious about. For CA people I'm not sure I can get an answer from someone with experience because 2015 cars don't need smog till 2021, so any speculation in the meantime? Just genuinely curious because like someone else said, the turbos look nearly identical, and if I have a stock tune I wouldn't expect the emissions to be worse because it's still should be pushing light boost?
Depends on the shop and the car I suppose. You could have a 700HP Kia, and they might not even pop the hood if it looks mainly stock on the outside because it's a Kia. GTI and an R, they might, though cops will make you pop the hood if they're feeling like it with those cars and you get popped for loud exhaust.Are smog shops really looking at stamped part codes on cats in CA? I doubt it. I would think if you have a tune that maintains readiness, a downpipe that doesn’t scream it’s aftermarket with obvious logos, and a cat that doesn’t throw a CEL (spacer or not), you pass.
What I’m really interested to find out is what people with MPI setups are doing to pass in CA. Do you just flash back to a stock file? Any issues passing or do you actually need to remove fueling hardware?
CA resident, I have stuck with the stock downpipe on my GTI. Honestly I have been fine with Stg1 and have both 91oct and E30 profiles. The E30 profile is more than enough for this FWD car. I probably would be looking at an R for the AWD if I wanted to have more HP than I do currently. Most of my drives are in the mountains where the corners keeps my speed in check. Not really going over 80mph often and I like the low end torque of the IS20 so bigger turbos are not as desirable to me.
I purchased mine new in 2016 so I still have time before I have to take it in to get inspected. Still though I dont want to deal with flipping parts back and forth then. I plan on keeping my car until it financially doesn't make sense. For me that is a years worth of repairs exceeding a years worth of new car loan payments. I expect to get about 8-10 years out of the car like I did my MK5 before this.
What ethanol sensor are you running? I’m back and forth on whether to move to a Cobb AP or just jump to an is38 and stick with APR.
Currently I’m not running an ethanol sensor. I’m doing the math each fill up and testing the pumps ethenol content each time. Thankfully the pumps around me are very consistent around E80 reguardless if it’s Pearson or Propell as the fuel provider.
I’m very happy with Cobb and EQT, you won’t regret making the switch.
Test kits adding up ? I fill up 1-2 times a week so that would become very tedious after awhile![]()
Testing is just a plastic tube you fill with water to a line and the rest with E85. https://www.carworklog.com/2020/07/18/testing-the-ethanol-content-of-fuel/
If I go with an IS38 on my wagon and use something like a stock R downpipe, would I be able to just flash to a stock tune and drive very gently to the smog station and then swap back? The downpipe will look stock and the turbo doesn't look very different from where it's positioned in the engine bay.
I guess the main issue would be driving the ~50-100 miles to get the stock tune's readiness sensors cleared with the IS38. Probably would run like crap.
