How many people run an aftermarket downpipe in CA?
Jakeokj
Southern California
Mk7 GTI
I bought a mk7 GTI a couple months ago, went stage 1 and am looking to go stage 2. I know I need a downpipe which is obviously illegal in CA and I’m wondering if it’s a common thing for people to do? If so what are the best options for downpipes?
D run
SoCal-sfv
Yeah pretty common. Just have to remove it when its time for another smog check. think its 2-3 years. Everyone will have their opinions on best options. mine is from MAP.
Also, the install isnt too bad. I did it by myself (basic mechanic skills. haha) just a thought so you dont pay to have it done .Save you some cash.
Jakeokj
Southern California
Mk7 GTI
Got it thank you so much! Loving the car
Jakeokj
Southern California
Mk7 GTI
Also does the MAPerformance downpipe smell much? With catt
anotero
Hither and thither
Mk7 GTI
I have a MAP dp as well, and also did the install myself. Easy procedure.
anotero
Hither and thither
Mk7 GTI
Doesn't smell at all inside. Not bad outside either. I've been running mine for a year.
billbadass
your moms house
i also have MAP downpipe and I asked them to make me one that did not have their logo on it so under the hood looks stock to someone who doesn't know what they are looking at like a random smog tech or a cop. when time to smog will just swap stock DP back on and put back on stock tune and stock intake and I've heard running a gallon or two of E85 in the tank helps lower smog emissions too
Father Seth
SoCal
2015 Golf TSI
I'm running the CTS 3.5in DP on the Golf 1.8t. I have an IS20 installed, and was wondering if I flash to stock on the IS20 turbo, whats the likelihood of me failing?
My car needs to be smogged in about a year, so I'm not in a rush. I just dont know the science/engineering behind the emissions on a stock tune with the upgraded turbo.
Jakeokj
Southern California
Mk7 GTI
In CA you cannot upgrade your turbo and still pass smog. I’m not 100% sure about running a stock tune with the upgraded turbo I would assume you would have to turn everything back to stock to pass. Double check though.
Jakeokj
Southern California
Mk7 GTI
Gotcha, I had the same idea with looking stock so I found a downpipe without logos. Wish I got it done by MAP
Faceman
Long Island
'17 GSW 4Mo
Is a tech going to check the part numbers on the turbo?
Installed on the car and with the heat shield in place, they look virtually the same.
StorableComa
Long Beach, USA
17 GSW S
Biggest issue would be the ODB2 hook up and readiness with the tune. They don't do sniffer smog anymore on newer cars in CA, it's a visual inspection and a readiness check. Currently I think APR has one on the 1.8T for an IS20 swap using the GTI DP, but I don't believe I've read of any IS32 stock DP tunes that will pass readiness on the GTI or 1.8T
Turbo if a OEM version might be okay, DP is questionable as I believe they look for CARB numbers on the DP. Not completely sure on that, with the heatshield in the way and a lazy tech you could get away.
