MKSeven
- Las Vegas, NV
- mk7 gti, duh.
Fair enough.Maybe. You get used to it. Also, I'm not a bitch.
That's wild your DMF broke. Definitely some dumb luck you've had. Albeit- I've definitely have had issues with my SB Slave cylinder leaking and needing to replace that. I just installed DKM, no issues so far, still breaking it in so we'll see how well it is.Dual.
No I have not, I have not launched this clutch… did that with my FX500 with a dual mass and broke DMF, then when I switched to dkm stage 3 (hated that clutch, had issues and it never felt right, then the dkm tob popped after like 5k) now after 25ish k on this once I’ve not had the nerve to hard launch it since I had so much bad luck with clutch work.
If you’re interested in seeing how it launch’s I’m gonna have to rescind my invitation to test drive the car
Well, not to scare you but I broke my DKM Stage 3 clutch on a hard launch. The DKM can handle spirited driving and canyon runs no problem. Probably even auto-x events, pushing it hard but definitely not for drag racing. My SPEC clutch grabs instantly because it was designed for popping the clutch on hard launches and the break-in period and clutch pedal was way easier than the DKM break-in. The DKM eased up after the first 500 miles but nothing like my SPEC clutch.Just trying to see what everyone is running. I run DKM stage 3 and I'm barely breaking it in now. I was shocked at how heavy it was compared to the SB stage 3. My foot actually got sore. I don't know how you guys do it. Especially your 800 tq rated clutch.
Mine started slipping after 20K or soI’m on the Sachs SRE (rated at 400) and so far so good?
Dual.
Never really been a dig type of guy, more of a roll person. But, I will some times do digs and try to avoid prepped surfaces.Well, not to scare you but I broke my DKM Stage 3 clutch on a hard launch. The DKM can handle spirited driving and canyon runs no problem. Probably even auto-x events, pushing it hard but definitely not for drag racing. My SPEC clutch grabs instantly because it was designed for popping the clutch on hard launches and the break-in period and clutch pedal was way easier than the DKM break-in. The DKM eased up after the first 500 miles but nothing like my SPEC clutch.
Maybe next clutch will be ACT or SPEC?Mine started slipping after 20K or so
Went ACT like some others. Light pedal, lots of grab, buttery shifts
Well I spoke too soon...I guess @railroader's tune is a little too spicy for my worn out clutch.I’m running an HS tuning RSR hybrid clutch and stock DMF on my setup. Not pushing 450 wtq but seems to be holding up well at 420-430 ft-lb.
Who is he tuned by if you don’t mind me askingWell I spoke too soon...I guess @railroader's tune is a little too spicy for my worn out clutch.
Just don't skip leg day and it's fine for a daily.[knocks on wood] I have been running a DKM stage 3 twin disk for about 20k miles. Decent clutch that takes everything I throw at it but still heavy even a couple of years later. Not recommended for a daily driver.
You got 70k+ out of it lolWell I spoke too soon...I guess @railroader's tune is a little too spicy for my worn out clutch.
Yep. But to be fair it only had to put up with a subpar hybrid and a conservative tuner for most of the 75k miles I put on it.You got 70k+ out of it lol
Sorry not sorry hahaYep. But to be fair it only had to put up with a subpar hybrid and a conservative tuner for most of the 75k miles I put on it.
Now that I have a better turbo and superior tuner, I’m finding the weak components in my setup.
