How is your COBB mounted?
swcrow
What holder is that and how are you running the wire? Looks clean.
wizgear off Amazon. I ran the cable from the OBD plug up through the dashboard without having to cut or Dremel anything
Daks
Toronto
GTI PP
By the steering wheel? It's a very clean install.
swcrow
exactly.....tight, but it comes up right in between the steering column and other piece. You have to route it through the bottom, and then pull up on the cord to connect.
CaptainRatty
Winston-Salem, NC
MK7 GTI
This is the only thing that stops me from going EQT. I don’t really want anything mounted on the dash like that.
That's silly... Just tune and throw it in the glovebox; it's not required to be plugged in.
Wastegate13
SoFla
So don't? Unless I'm monitoring or actively logging it stays in that little cubby by my knee.
gixxerfool
New Jersey
2016 Golf R
Oh. Man. I’m a dummy. I was under the impression it had to be plugged in all the time, like a piggy back.
CaptainRatty
Winston-Salem, NC
MK7 GTI
The more you can not look at it and just trust that your car is well maintained and the tune is well done the better… some people lose their shit over the smallest bit of knock or one of the other hundred + parameters that can be monitored. Not saying that’s you, but as you indicated, you don’t want to have it plugged in and it doesn’t need to be. Tune, run a WOT log to confirm everything is good, and enjoy.
gixxerfool
New Jersey
2016 Golf R
Great now I need to spend another grand...dammit!
Daks
Toronto
GTI PP
But.... racekar.
