Well you are correct and well written.
Petrol cars use one wide band lambda pre cat and one narrow band post cat. Usually there are maybe some cars that dont have that setup but they are rare.
I used to tune RX-8 cars and have seen some BMW tunes aswell.
Closed loop on an RX-8 is only under 3400 RPM (if I remember correct, it was some years ago now) and steady state and is only driven by readings from the wide band lambda. Open loop is then you use the gas pedal and then the car uses AFR tables and readings from a MAF sensor.
But modern cars are smart and can adjust them self some. I know when I tested piggy back unichip the RX-8 over time compensated for the Unichip and the tune was almost gone. You have to reset the cars LTFT (long time fuel trim) by disconnect the battery for min 20 minutes.
Thats why remap always is superior to try to foul a modern ECU, I dont know how the GTD ECU works but maybe its the same here. The GTD self compensate with the LTFT to make the Box ineffectly?
I know to little about diesels and the GTD to say it will be like that but one thing is sure. Its always better to remap then try to foul a modern ECU.
