impulsive.ca
Even then, driver mods and other variables make more of an impact, at least in my opinion. I'm not shitting on stg2 hardware/tunes, Im just having a difficult time justifying the cost:benefit ratio.
I will say I had the same impression with my 3 Subarus. The DP makes a huge difference in throttle response and spool.Even then, driver mods and other variables make more of an impact, at least in my opinion. I'm not shitting on stg2 hardware/tunes, Im just having a difficult time justifying the cost:benefit ratio.
If you're manual, once the clutch starts to slip, that's when you start going down the rabbit hole. The clutch and the install are the expensive parts, the downpipe and tune upgrade are not. I experienced a noticeable enough difference in daily drivability, response and power to have made the stage 1 to 2 jump worthwhile for me.Even then, driver mods and other variables make more of an impact, at least in my opinion. I'm not shitting on stg2 hardware/tunes, Im just having a difficult time justifying the cost:benefit ratio.
Definitely no slip on stg 1 91 Oct yet, knock on wood, but I won't go WOT on the street in 4th, 5th and 6th. On track, I don't think it's an issue, because you're not pulling from low rpms in those gears.If you're manual, once the clutch starts to slip, that's when you start going down the rabbit hole. The clutch and the install are the expensive parts, the downpipe and tune upgrade are not. I experienced a noticeable enough difference in daily drivability, response and power to have made the stage 1 to 2 jump worthwhile for me.
Your discipline > mine. I can't resist pushing it in 4th, but I never did under 4K RPM, and it still slipped on a uni stage 1 file. Mind you, the car was used when i purchased it so I am unsure of the other drivers habits. I had a Stage 2+ MK6R that I kept on the stock clutch for over 60,000KM.Definitely no slip on stg 1 91 Oct yet, knock on wood, but I won't go WOT on the street in 4th, 5th and 6th. On track, I don't think it's an issue, because you're not pulling from low rpms in those gears.
When it does slip, I'll go stg 2 after new clutch.
At least going by EQTs dyno, it's only like 15 hp and 3 torque. I updated my clutch for stage 1, but don't really have any interest in adding a downpipe and going stage 2. There's a better chance of me buying a catback before a downpipe + tune upgrade.I had a stg2 mk7 gti with a 6spd. Between clutch slipping and loss of traction, I'm glad I upgraded to an R with dsg.
Dp install on a gti without the LS was easy AF. On an R with haldex in the way? Not so much. 30whp isn't worth it, but that's my opinion. You do as you want.
I should have known saying +400hp would lead to the usual quibble fest about tuners and dynos and blah blah blah.The IS38 is past its peak at 6000 RPM so I agree that about 400 HP is tops. With a blow the motor tune and the right dyno you might see 430 HP once or twice.
Seeing times between max effort Is20s on custom tunes Vs ots plain Jane 38s I don’t think the performance jump between the 2 will astound you... now going hybrid with associated fueling, I can say that’s a sureal jump in power-lol
Honestly you should email Sneeky - hes quick to respond and can help steer you...maybe going with a hpfp and full e85 on the Is20 will yield you the results you want...he’s very familiar with both setups so he can give you direct results.
Cake/eat/free, haha! Ah I forgot
You still pretty much remote working? Of your office is still near mine - there is a station that’s essentially on the way at trop and Vally view of you take 95, I use that one when I can since it’s always at 70-80% vs Murphy’s at 60-65%. Just gotta take extra caution to Avoid eye contact with the people hanging out from the budget suites.
Sorry, for the temp derail.Not sure why you're talking about sneeky in a discussion about EQT tunes. FWIW, we also offer all manners of custom tuning and can get anyone set up with whatever setup and fuel meets their goals.
Thanks
-- Ed
