Looks like that mod list is paying off!AMS dp, magic twincooler, rs7 plugs, apr coil packs, apr exhaust, afe open intake and the turbo intake/exhaust nonsense. Thanks for looking at it!
Grab a test kit and an ethanol content gauge. You'll notice that the E content fluctuates slightly from one fill up to the next.My next step after fluid changes is the E30 tunes. Have any logs? Using any E content gauges?
Stage1 E30 numbers are nuts.
I also hit 29 in 4th in similar weather, both on the 91 and 93 tunes.How much boost are you guys seeing/peaking at? I know this is dependent on other variables but wanted to ensure my peak was "normal" for EQT tunes.
The other day I peaked around 29PSI in low 30 degrees outside - located in eastern PA. EQT stage 1 91octane
29PSI measured with relative manifold pressure.How much boost are you guys seeing/peaking at? I know this is dependent on other variables but wanted to ensure my peak was "normal" for EQT tunes.
Relative manifold pressure was 28.8psi and boost was 29.029PSI measured with relative manifold pressure
I love the cold weather but boy is 2nd gear completely useless now, so far loving the stage 2 file! It pairs nicely with some crackles in between shifts.
Does anyone else find the throttle input to be extremely touchy?
Yeah I just got the tune a couple days agoAre you on the latest update? This solves the touchy throttle issue I had with me 2019.
No knock across the board.. nice! I'm no expert at reading these by any means, but are you maxing out the HPFP from 3520 RPM to 4768 RPM in datalog 2?Couple logs. EQT stage 1 running E30
https://datazap.me/u/themechanicdude/eqt-ots-stage-1?log=0&data=8-14
