BigCanoe
- Moncure, NC
- 2017 GTI SE DSG
I was thinking today, I need to check my oil. How often do you check yours? And do you drive the car first, and then let it sit and check it warm?
Do you get a higher reading when its cold in the morning than after it runs and settles back down? Or is it the other way around?
I thought there was a valve in the filter housing assembly which prevented all of the oil from draining down to the sump.Higher when engine is cold.
