SVOMikey
- Denver, CO
- GTI, SVO, RSX
Help! I’m at wit’s end. I have a high-speed (78-85mph) vibration in the front of my 2015 GTI/PP w/manual gearbox. It has been there since the day I got it off-lease from dealer w/ 25K miles. It is felt in the seat and a little in the steering wheel. Months later I jumped a curb and replaced all of the front right suspension, all wheels, tires and bearings. Vibration was still there. Threw the car on a lift and ran up to speed with LCAs & wheels dangling in the air. LCAs were flopping around quite a bit. I Jammed a crowbar in between the LCA and frame and it died down a bit. The LCA bushings were very sloppy.
I took it to a shop that said it was the right CV axle. They swapped with new OE axle and said it was happy. It is not. Still there.
I swallowed my pride and brought it to the dealer. Worst auto experience of my life. To escape any liability, they refused to listen to me when I said it did it from day 1 and blamed the tires/wheels I put on as well as the subframe which had slight damage from running up on the curb. Basically, all stuff changed months after the vibration was 1st noted.
Out of spite I have gone to the Audi aluminum subframe and a solid rubber LCA lower bushing and it hides the vibration quite a bit with the harsher ride but it’s still there. The car feels like it has a full set of coil-overs just from changing to the solid TT bushing!
So... The car has new aftermarket wheels/Michelin tires, all new OE suspension on the right front, new rotors, pads, wheel bearings (all 4), new OE Right CV axle. The car aligns perfectly. The tires have been road-force balanced a few times and it may help a little but does not eliminate the vibration. Again, the subframe and rear LCA bushings have been changed.
The car has the original left front suspension and CV axle. My local CV shop says they have no way to tell if the axle is bent. I thought they could spin it like a driveline shop does with a prop shaft but they claim no dice. The shaft is so far above the subframe I really doubt anything damaged it. So I really go to worst case scenario and think it’s the output shaft of the diff. Thoughts?
Today I stuck a run-out gauge on the ends of the CV axles but couldn’t get on the joints themselves. Both original and new shafts seem to have about 5 thousands of play on the painted surface at either end of the axle before it goes into the joint. It is likely not a valid test. I also stuck it on the vented edge of the brake rotor and saw about the same number. Again, both new and old look about the same.
So it turns out ATS makes a fantastic NVH test set for finding stuff like this but no one in CO or NM has one. )-:
Any suggestions on next steps? Any shop recommendations in Colorado that has enough of a clue to help? Thanks all. Sorry for the long post. Mikey in Denver.
