Hi seeking professional Tuning Shop in Los Angeles/Orange County that can install my Parts I bought from ECS Tuning. Cobb + Dyno Support if possible.
Hi I'm Chris,
Brand new to these Forums (in general). I have a 2017, MK7 GTI, 6-Speed Manual with barely 16,000 miles. I recently purchased Parts to upgrade my Car. Majority of the Parts are from ECS Tuning with Cobb Accessport V3 as well. I'll post all the parts I bought so people can guide me to which Shop is best. Distance is no issue really, just a LEGIT place that I can also go back for Maintenance/etc. Professional, Dyno, knowledgeable, friendly & clean. Also that accepts Credit Cards.
Parts (needing to be installed):
Front RedStuff Performance Brake Pad Set
(https://www.ecstuning.com/b-ebc-parts/front-redstuff-performance-brake-pad-set/dp32127ckt1/)
StopTech STR-600 High Performance Street Brake Fluid - 500ml
(https://www.ecstuning.com/b-stoptech-parts/stoptech-str-600-high-performance-street-brake-fluid-500ml/501.00001~stp/)
RS Ignition Service Kit
(https://www.ecstuning.com/b-assembled-by-ecs-parts/rs-ignition-service-kit/06h905110lkt3/)
Front and Rear Slotted 2-Piece Semi-Floating Brake Rotor Kit (340x30/310x22)
(https://www.ecstuning.com/b-ecs-parts/front-and-rear-slotted-2-piece-semi-floating-brake-rotor-kit-340x30-310x22/013928ecs03-01kt/)
Kohlefaser Luft-Technik Intake System - With Carbon Fiber Inlet Tube
(https://www.ecstuning.com/b-ecs-parts/kohlefaser-luft-technik-intake-system-with-carbon-fiber-inlet-tube/009199ecs01-02kt/)
Blow-Off Valve Kit
(https://www.ecstuning.com/b-forge-parts/blow-off-valve-kit-limited-edition-purple/fmdvmk7ap~frg/)
Clutch Pedal Upgrade Kit - 6 Speed + Billet Clutch Bleeder Block
(https://www.ecstuning.com/b-ecs-parts/clutch-pedal-upgrade-kit-6-speed/018733ecs01kt/)
ECS Tuning Baffled Oil Catch Can System
(https://www.ecstuning.com/b-ecs-parts/ecs-tuning-baffled-oil-catch-can-system/014726ecs01-01kt/)
Solid Shifter Cable Bushing Upgrade Kit - Rectangle 8.5mm (F2B) - Round 10mm (S2S)
(https://www.ecstuning.com/b-ecs-parts/solid-shifter-cable-bushing-upgrade-kit-rectangle-85mm-round-10mm/003929ecs0102akt/)
Shifter Mounting Bracket Bushing Upgrade Kit
(https://www.ecstuning.com/b-ecs-parts/shifter-mounting-bracket-bushing-upgrade-kit/003929ecs05~a/)
Secondary Air Filter Adapter Kit
(https://www.ecstuning.com/b-ecs-parts/secondary-air-filter-adapter-kit/009200ecs02~a/)
Performance Dogbone Mount
(https://www.ecstuning.com/b-ecs-parts/performance-dogbone-mount/010935ecs01kt2/)
ECS Tuning Stage 2 Performance Clutch Kit with Lightweight Forged Steel Flywheel (18.85lbs)
(https://www.ecstuning.com/b-ecs-parts/vw-mk7-gti-golf-r-gen3-ecs-tuning-stage-2-performance-clutch-kit-with-lightweight-forged-steel-flywheel-1885lbs/015123ecs01kt/)
VW/Audi Gen3 Turbo Inlet & Turbo Muffler Delete Pipe Kit
(https://www.ecstuning.com/b-ecs-parts/vw-mk7-mkvii-golf-gti-gsw-alltrack-tiguan-mqb-golf-r-2015-2016-2017-2018-2019-audi-8v-a3-s3-mk3-mkiii-tt-tts-18t-20t-gen3-gen-3-mqb-turbo-inlet-pipe-tip-turbo-muffler-delete/020797ecs01kt/)
MK7 Front Mount Intercooler Kit - With Red ECS Charge Pipes
(https://www.ecstuning.com/b-ecs-parts/mk7-front-mount-intercooler-kit-with-red-ecs-charge-pipes/023624ecs02-02kt/)
Billet Dogbone Mount Insert - Version 2
(https://www.ecstuning.com/b-034motorsport-parts/billet-dogbone-mount-insert-version-2/034-509-1025~034/)
Harmonic Damper Crankshaft Pulley
(https://www.ecstuning.com/b-fluidampr-parts/harmonic-damper-crankshaft-pulley/551231~flu/)
European Short Shift Kit
(https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/european-short-shift-kit/8j0711046e/)
COBB Tuning AccessPORT Tuner V3 (https://www.ecstuning.com/b-cobbtuning-parts/cobb-accessport-v3/ap3-vlk-002~cob/)
CTS Turbo 3.5" High Flow Downpipe
(https://www.ecstuning.com/b-cts-parts/35-high-flow-downpipe/ctsexhdp0014cat/)
Valve Spring Tuning Kit
(https://www.ecstuning.com/b-forge-parts/valve-spring-tuning-kit/fmtvtun/)
Hex Socket Bolt
(https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/hex-socket-bolt-priced-each/n91167101/)
Crank Pulley Bolt
(https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/crank-pulley-bolt-priced-each/wht001760/)
Please & thank you.
-Chris
GTI_Jerm
SoCal
I recommend AUTuning in Huntington Beach. Been going there for pretty much all maintenance and aftermarket installs. One shop I highly recommend you DONT go to is _______. You could PM if you’d like to know 🙃
c72k
Cali
Pacific German? Lol
I’d highly recommend emmanuele design in Anaheim. Super nice guy and very knowledgeable. Also metric in Huntington is legit
GTI_Jerm
SoCal
Pacific German? Lol
Nope. Don’t really wanna just call them out on here, but I will say the overcharge and owner comes off as a major douchebag. Maybe I caught him on a bad day, but even one of his former employees said it wasn’t a good environment.
+1 on Emmanuel Design, just a bit further from me so I opted to just stick with AU.
One thing that I didn't see on your list of parts is a rear sway bar. I got the Neuspeed 25MM one and it works great neutralizing the understeer.
After I burn through my Tires, I'm getting Sway Bars, (new) Tires & Wheels at the same time. Want to keep Suspension Stock.
Keeping my car under the radar right now. Thank you for the recommendations on Parts.
:D
Handguns4heaRTs
So Cal
Ride
2017 GTI SE DSG
If you're looking to get tuned via your Accessport, I would contact 5150. That way you could just drop your car off, have everything installed, and get dyno tuned all at once. You'd save time and money, and be tuned by one of the best in the game. If you're just looking for install- AU Tuning, Emmanuele, or Metric. I like Metric the best.
9uns
Anaheim
Holy parts haul. TBH you could probably save some coin by installing some of the parts yourself, i.e. intake, dogbone mount, short shifter, etc. I don't have any experience with AU or Metric but a lot of CA guys swear by their customer service. I've gotten an alignment from EMD and the guy that was in the office was very friendly and seemed very knowledgeable. Either way, let us know where you go for the tune as I'll be in the same boat in a year or two.
I would but I have a Disability. Hence why I'm here haha.
