Help with bad turbo?
wave
SW Florida
Hey guys, I've been having issues with my car. 2016 GTI S. Stock turbo, no tune. I have a log from OBDeleven here also.
The turbo doesn't seem to be making much boost, because the car is very sluggish. It also continues to throw an EPC light whenever I stay on the throttle and it builds boost fully.
If I don't clear the EPC, the car drives like an old naturally aspirated Civic.
My buddy thinks the turbo is shot. Any advice is appreciated!
Car: Volkswagen Golf
Year: 2016
Body type: 3-dr hatchback
Engine: CXCA
Mileage: 158499 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259D
Software version: 0004
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259D
ODX version: 001005
Long coding: 091900122424002F0000
Trouble codes:
P010600 - Manifold Abs.Pressure or Bar.Pressure Range/Performance
static
Date: 2022-04-18 16:49:45
Mileage: 158377 km
Priority: 2
Malfunction frequency counter: 5
Unlearning counter: 255
Engine speed: 4877.75 1/min
Normed load value: 100.0 %
Vehicle speed: 162 km/h
Coolant temperature: 88 °C
Intake air temperature: 45 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.222 V
Dynamic environmental data: 209628110E0311EC0211DC049811EDED10A600DB11EEDB11DB07DD
P023600 - Turbocharger Boost Sensor (A) Circ. Range/Performance
static
Mileage: 158377 km
Priority: 2
Malfunction frequency counter: 3
P045600 - EVAP Emission Contr. Sys. (very small Leak) Leak Detected
static
Date: 2022-04-18 06:21:33
Mileage: 158280 km
Priority: 2
Malfunction frequency counter: 1
Engine speed: 1061.75 1/min
Normed load value: 49.8 %
Vehicle speed: 0 km/h
Coolant temperature: 28 °C
Intake air temperature: 24 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.535 V
Dynamic environmental data: 209628110E0211EC0111DC001111ED4410A6011E11EE2911DB0267
03 Brakes
System description: ESC
Software number: 3Q0907379T
Software version: 0393
Hardware number: 3Q0907379C
Hardware version: H32
Serial number: 51635000000895
ODX name: EV_Brake1UDSContiMK100ESP
ODX version: 034033
Long coding: 01FA6BA1342009710077020881CB2980D62C9000408194B400430050C004
Trouble codes:
No trouble codes found
08 Air Conditioning
System description: AC Manuell
Software number: 5GM907426A
Software version: 1001
Hardware number: 5GM907426A
Hardware version: H02
ODX name: EV_ACManueBHBVW37X
ODX version: 003019
Long coding: 00020004300100000000000000000002
Trouble codes:
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087AA
Software version: 0162
Hardware number: 5Q0937087AA
Hardware version: 028
Serial number: 86581905152765
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 015002
Long coding: 000008464001804969644000001407201000000000000000000000000000
Subsystems:
System description: WWS 150425
Software version: 0581
Hardware version: 043
Serial number: 150702133041
Long coding: 0E4DDD
Trouble codes:
B121715 - Left low beam headlamp bulb Open circuit/short circuit to B+
static
Date: 2022-04-18 06:21:22
Mileage: 158280 km
Priority: 1
Unlearning counter: 247
Terminal 15 status: On
Terminal 50 status: Off
Voltage: 14.0 V
Outside air temperature: 22.5 °C
Status Bremslichtschalter (HW): Off
Status Bremslichtschalter (CAN): Off
Off: not activated
Parking light: not activated
Automatic high beam assist: not activated
Low beam: operated
Parking light left: not activated
Parking light right: not activated
Letzte Weckursache/ Werte [00;2E]: gültiges Funktelegramm
CAN-Bus_aktiv: On
B12BB15 - Right front side marker lamp bulb Open circuit/short circuit to B+
Intermittent
Date: 2022-04-19 06:20:36
Mileage: 158402 km
Priority: 2
Unlearning counter: 34
Voltage: 14.1 V
Off: not activated
Low beam: operated
CAN-Bus_aktiv: On
B1806F0 - Heated seat passenger's side Safety shutdon due to occupant detection
Intermittent
Date: 2022-04-17 17:34:18
Mileage: 158280 km
Priority: 6
Unlearning counter: 32
Terminal 15 status: Off
Voltage: 12.6 V
Outside air temperature: 32.5 °C
Off: operated
Low beam: not activated
Jose_Gti
Philadelphia
But you may actually considering the apr results?
Yeah…. At this rate if I don’t sell it soon I may switch turbos and call it a day…
gdub09
Omaha, NE
You probably have a boost leak some where
wave
SW Florida
What would make you think a boost leak? We've pressurized the intercooler charge pipes and they hold 30 psi, so no boost leaks found.
Jose_Gti
Philadelphia
I don’t think that’s the play. Switch tuners and get a dp on there
For me the reason to go with the Apr turbo was to avoid the DP. I had it but, after trying different resonators couldn’t live with the drone
