Help Required... Too rich at idle error
S3 Freak
South Africa
Hi gents,
Need some help with my audi S3 8v, the past 2 weeks been receiving the below error code:
Fuel control system 2 (bank 1)
(P21F9) too rich at idle
For the past 2 weeks the car starts Normal on cold start, but if I switch off and try starting again it does not. Have to crank a couple of times then it starts.
Did some research and replaced couple parts
PCV
O2 sensors
Injectors
Intake temp sensor
Checked for air leaks etc
Yesterday I noticed that if I remove the dipstick or remove my silicone hose to my boost tap (creating a boost Leak) the car starts immediately on the turn... Any idea what it could be? Seems like the car is choking or something :confused:
Regards
Hi gents,
PCV
O2 sensors
Injectors
Intake temp sensor
Regards
How many miles and how many miles on the spark plugs? I would have got it diagnosed before I started blowing money on parts. That's the risk you take replacing parts based on a code.
S3 Freak
South Africa
Car is out of warranty, I've tried locally and nobody is able to diagnose the problem lol... New plugs so that can be ruled out.
Don't like the idea of blowing money on parts unnecessarly, but but luckily I had a couple of spare parts which I tried on except for the injectors.
PacDawg
Gilroy, CA
Hi gents,
PCV
O2 sensors
Injectors
Intake temp sensor
Regards
Hey man. We've been conversating on FB since we have similar issues. Hope you figure it out. My cells are p2188 (System too rich at idle, Bank1) and p2196 (02 Sensor Signal Stuck Rich). Same hard start issues as you but also have issue with bad idle causing car to almost stall when idling. So far I've replaced plugs, PCV, Evap purge valve and front O2. I need to do smoke test next and if looks good check to see injectors or HPFP is bad.
Diggs24
de plains! de plains!
2015 GTI
Wonder if that brine didn't ruin one of those 2.
PacDawg
Gilroy, CA
xkeyscore
ca.us
I used to have a beetle and the crankshaft position sensor would go bad when warm preventing the car from starting.
Once it was started it was fine but if you stopped the car you had to wait for the sensor to cool down before it would start again.
Not sure if these engines have the same sensor, but it is something to think about.
PacDawg
Gilroy, CA
Looks like my issue was due to faulty injector. Injectors replaced and all seems good now. Hope you get yours sorted soon.
PacDawg
Gilroy, CA
S3 G
Birmingham
S3
Hi gents,
PCV
O2 sensors
Injectors
Intake temp sensor
Regards
Did you manage to get this sorted I have the same faults.
