I’ve seen the cigarette lighter 12v fuse that can stay on at all time. Will it drain my battery in the long run? Since this is for a cutout exhaust remote control? Or what other fuse can I tap this into?You’ll want a fuse tap aka add-a-fuse for this. They have them in various sizes on Amazon. Then you’ll need to find the correct fuse in the fuse box to use.
I think you have that backwards. The cigarette lighter fused is switched and it turns off with the ignition. I used a add-a-fuse for my dash cam and I went with the cigarette lighter fuse. I will have to look once I am off work to see which fuse it actually is.I’ve seen the cigarette lighter 12v fuse that can stay on at all time. Will it drain my battery in the long run? Since this is for a cutout exhaust remote control? Or what other fuse can I tap this into?
The add-a-fuse taps have short flying leads so you can connect the wires from your accessory to. They are not meant to be a "wiring harness" that runs to your accessory.They didn’t have me long enough wires I didn’t feel like going to get extra wires
