Help Needed - OEM Install of Front Brakes - Missing Banjo Bolt
TecklenburgVW
Saint Cloud, FL
Hey folks,
I've uninstalled my StopTech Trophy Sport BBK and started the re-install of my OEM setup but can't find the banjo bolt that connect the brake line to the OEM caliper. I've tried using part catalogs but it appears you have to purchase a brand new OEM brake line from Volkswagen to get the banjo bolt. Anyone know how to source just the banjo bolt? FCP Euro shows several in there parts catalog with several different part numbers.
I'm planning to go to Ace Hardware in the morning to see if they have any in stock.
NCM
Fort Wayne, IN, USA
2015 Golf R
That's not something you'll find at the local hardware store. Note that you'll also need new crush washers, qty 2 per banjo bolt. New brake lines with bolts and washers are only about $21 online; may not be the worst solution. ECS has VW banjo bolts, but apparently not for the Mk VII Golf family.
Neil
George Ab
Pacific NW
Consider removing banjo bolt from side you have and go to local auto parts store and marry up with what they have. My local O'Reilly has a couple in stock all others are one day order; $5 to $6 is price.
