help! MK7 GSW Factory R Bi-Xenon lights Retrofit
Kuzya
Toronto, Canada
2017 Sportwagon 4mo
It certainly is not "the right one". This BCM is the newer type that does NOT use an active long-code string.
I have no idea how, or why 0E4DDD is present in your BCM - but it's most definitely not correct !! My advice -remove the long code value (enter ALL zeros)
For your right High-beam problem do this:
  • Leuchte11SHUTTER RB22 - Lichtfunktion A 11 >Fernlicht rechts
Don
@DV52 thanks a lot it works well! About the long code, I've never touched that string, assuming it came like this from factory [Edit - looked up my backup before the upgrade, and it has the same long code]
Aaron1875
England
Mk 7.5 Golf R
The 5G0-941-753-C/5Q0-941-754-C Headlights are MK7 Golf R Housings and should have 4 modules each:
1 AFS Controller
1 Xenon Ballast
2 LED controllers (one for the U-lights, the other is for the LED turn signal)
as far as your BCM, 5Q0-937-087-AN is completely compatible with OEM Xenons, so no change required there.
What is your current gateway part #?
For 4Motion, you need one level sensor in the Rear Left, it is Part# 5Q0-512-521-G
Other than that, I think you have just about everything needed :)
Aaron1875
England
Mk 7.5 Golf R
Hi Somnus, I saw this post that you contributed to about retrofitting Golf R Mk7 headlights to a Golf Mk7 2017 which allegedly had Mk7.5 BCM software /hardware ?
I’m in a similar situation where my Mk7.5 Golf TSI EVO NAV 2018 was retrofitted with Mk7 Golf R front and rear lights along with full exterior refinements and full interior Inc steering wheel roof lining and air bags from an engine water flooded Golf R. The issue I have is that Vehicle Fault lighting error comes up when starting vehicle. The lights work fine except I know I don't have AFS and suspect previous owner did not hardwire the level sensors. I asked Uwe, the moderator in Ross tech and he was thrown by my BCM module and was convinced it’s an earlier type ?
My lights work, but as afore mentioned I don’t think I have AFS cornering lights function because that module is not installed and it’s not coming up on the Installed section of VCDS,
Q1. Is it possible can’t be reached due to incorrect coding ? I doubt whether the level sensors were coded out either, because they’re definitely not installed on the axles.
The only issue that bothers me is the Vehicle Fault Lighting error in start up.
Q2. Is there a way of isolating and coding ot out via VCDS ? Interrogating cent Elecs VCDS shows ‘ ‘Incorrect coding lighting module’
Here’s a Scan of Cent Elec’s module ?
3. What type is it ? Does it support Xenon HiD’s ?
Below the cent Elec’s, I’ve Inc Auto Scan (ignore HVAC faults, I retrofitted a Dual Climatronic, replacing Climatic and I’m missing essential hardware, hence the faults. It works fine on Synch mode no left and right lol)
Friday,12,May,2023,18:49:52:06045
VCDS Version: Release 23.3.1 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 09: Cent. Elect. Labels: 5Q0-937-08X-V2.clb
Control Module Part Number: 5Q0 937 084 DB HW: 5Q0 937 084 CE
Component and/or Version: BCM MQBAB M H38 0273
Software Coding: 7A99CB2A08A90900003000302C4880C00FC2404060030000300010000000
Work Shop Code: WSC 19460 666 12345
ASAM Dataset: EV_BCMMQB 019001 (VW37)
ROD: EV_BCMBOSCH_019.rod
VCID: 7BA89AE1A36419025A9-802E
Fault Codes have been Erased
1 Fault Found:
526615 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert->Keine Anzeige]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.0 V
Outside temperature: 14.0 °C
Auto Scan
Saturday,13,May,2023,01:09:32:06045
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-NET2 CB: 0.4631.5
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWZZZAUZKW029607 License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F 80
VIN: WVWZZZAUZKW029607 Mileage: 40946km-25442miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DACA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AK HW: 05E 907 309
Component: R4 1.5l TFS H22 6323
Revision: 81H22000 CVN: 5056196C
Coding: 0125003223641D0860000200000000000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM15TFS01105E906018AK 003003
ROD: EV_ECM15TFS01105E906018AK_VW37.rod
VCID: 6E8EA3B5E0167CAAED7-803A
VINID: 9E69EAAAA465A9B9C00891801C46664032
Radiator shutter:
Subsystem 1 - Part No SW: 95B 965 501 S HW: 95B 965 501 S
Component: V544KJS1 H12 0109
Serial number: 20180826020103050434
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 041 R HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1608
Revision: 00005008 Serial number: CU501809087610 CVN: 77C26D05
Coding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW26.rod
VCID: 44DA211D9E1AA6FA6B3-8010
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DE HW: 5Q0 614 517 AD
Component: ESC H25 0524
Revision: 00000000 Serial number: 62478000000481
Coding: 01FA8AA124222175477D060060CA2980512484E26006947338225078C202430B00000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 77A086D19F4C3D623E1-8022
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004200100011000000000101002
Shop #: WSC 00078 790 12345
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6A86AFA5DCFE908AB1F-803E
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
11 Faults Found:
327941 - Motor for Left Temperature Flap
B108C 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Voltage terminal 30: 11.4 V
Outside temperature: 9.0 °C
Inside temperature: 18.2 °C
Left temperature flap - actual value: 144
Left temperature flap - actual value: 58.0 %
Temperature door left - Specified value: 203
328197 - Motor for Right Temperature Flap
B108D 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Right temperature flap: actual value: 0.0 %
Right temperature flap: actual value: 239
Temperature door right - Specified value: 200
328199 - Position Sensor for Right Temperature Flap Motor
B1095 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
329989 - Motor for Defroster Flap
B1090 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Defroster flap: actual value: 16
Defroster flap: actual value: 0.0 %
Defrost door - Specified value: 15
329991 - Position Sensor for Defrost Flap Motor
B1098 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
328965 - Motor for Front Air Distribution Flap
B1091 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Front air distribution flap: actual value: 92
Front air distribution flap: actual value: 40.0 %
Air distribution door front - Specified value: 169
329477 - Motor for Fresh Air / Recirculated Air Flap
B108B 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Actual value for fresh air/recirculation air flow flap: 17
Actual value for fresh air/recirculation air flow flap: 0.0 %
Fresh air/recirculating air/back pressure door specified value: 78
329479 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
197378 - Temperature Sensor for Right Vent
B1088 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Vehicle speed: 0 km/h
262402 - Sunlight Photo Sensor
B10E8 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
262404 - Sunlight Photo Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DB HW: 5Q0 937 084 CE
Component: BCM MQBAB M H38 0273
Serial number: 00001825300823 Dataset Number: V03935280FM 0001
Shop #: WSC 19460 666 12345
Wiper motor control module:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180822 042 0551
Serial number: 180824115433
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S6Y18M09D05H23M15S48
Coding: 00A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140340BXK
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000045074244
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000011091804220325
3 Faults Found:
10762 - Bulb for Right Tail Light
B12BF 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 122
Mileage: 40927 km
Date: 2023.03.20
Time: 01:43:51
Terminal 15 status: OFF
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.5 V
Outside temperature: 16.0 °C
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018236 Dataset Number: V03935287MF 0001
Coding: 0471051811
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4CCA093DB64A6EBAA33-8018
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Dataset Number: V03935282JS 0001
Coding: 3300678151FFC728949C834580400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4HS9F. Dataset Number: V03935272MG 0001
Coding: 98CCC000000000005C0000CF008800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 0944F029F9B83B92585-805C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34169677B10121541406
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34169676B11121551255
Coding: 333135
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 001 109 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000DF7A0B13W
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 001 109 18
Component: SideSensor_Pf 001 0887
Serial number: 3580000000001BA41235
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 480 400 809 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A12BD5EC4956G
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 480 401 809 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001BF2BB7D22774H
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 712 15
Component: FrontSensor_D 001 6149
Serial number: 3550002C71E3EA9303DI
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 940 D HW: 5G1 920 940 D
Component: KOMBI 202 3610
Coding: 27A429082780060001886B011401000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009009
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 290490A919785B92785-807C
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008470419 Dataset Number: V03935288UN 0001
Coding: 030100047F085702FB08005C1C0F00000001070000000000000000000000
GVL: 01443C0000000000400C80000000C80000000000004000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D2C54F9FDF0D73224D-8068
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29150002320350095486
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 2465219104
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RHU06454 Dataset Number: V03935278QU 0001
Coding: 00310220D001048000001000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000023760294
Coding: 0D0000
1 Fault Found:
196883 - Function Lighting for Central Locking
B1783 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 40891 km
Date: 2023.03.15
Time: 00:40:56
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Dataset Number: V03935287HS 0001
Coding: 81170000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B8B2C18B345142029-8026
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RI11730E Dataset Number: V03935282ZH 0001
Coding: 00310020DC01048000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 43D822019B14A1C2529-8016
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000023699721
Coding: 150000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Serial number: Dataset Number: V03935282VN 0001
Coding: 02731001FF00000051110101008808001F0500C601200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 323677C534AE184AC9F-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2462289
Data carrier:
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
Serial number: --------------------
Address 80: Batt. reg. aux. accum. (A8) Labels: None
Part No SW: 5Q0 915 089 HW: 5Q0 915 089
Component: FMA H46 1073
Serial number: 770252-00021
Coding: 2F968A00
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_FMACATLVW37X 003007
ROD: EV_FMACATLVW37X_003.rod
VCID: 76BE8BD59846446A257-8022
End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.1V)--------
Aaron1875
England
Mk 7.5 Golf R
Don
Don I know it’s an old thread but wondering whether you or Somos could help. I came across this post that you contributed to about retrofitting Golf R Mk7 headlights to a Golf Mk7 2017 which allegedly had Mk7.5 BCM software /hardware ?
Note I’m a novice using VCDS, I’m trying to learn.
I’m in a similar situation where my Mk7.5 Golf TSI EVO NAV 2018 was retrofitted using an adapter plug loom with Mk7 Golf R front and rear lights along with full exterior and interior refinements.
The issue I have is that Vehicle Fault lighting error comes up when starting vehicle. According to VCDS the lighting module is incorrectly coded. However the main low beam xenon lights work, LED indicators work, U Lights work and High beam too. I’m pretty sure the AFS and FLA are not working, The AFS module is in the headlight but I’m not sure about FLA, the car has ACC radar is FLA governed by that ? Also I’m not sure whether my BCM supports these functions or whether those functions needed to be coded in, could this be the reason for the Vehicle Fault lighting error ? I also suspect previous owner may not have hardwired the level sensor(s) either.
where should they be located ?
I asked Uwe, the moderator in Ross tech about this issue and he was thrown by my BCM module. Despite my car being a 7.5 he was convinced from long coding that my BCM is an earlier type, which should be fine surely considering these are mk7 R lights. !
My lights work, but as afore mentioned I don’t think AFS cornering lights function work because that module is not showing ‘installed’ on the Installed module landing page on VCDS,
Q1. Is it possible AFS module isn’t showing because can’t be reached due to incorrect coding ?
Q2 Can the Vehicle fault lighting error be coded out, even if I don’t have FLA hardware and if I’m missing the level sensor ?
Q3. What type is it ? Does it support full range of Xenon HiD’s functions ?
Thanks in advance
www.Ross-Tech.com
1 Fault Found:
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
Auto Scan
www.Ross-Tech.com
Radiator shutter:
Coding: 0014
Revision: 00001K08
11 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:16
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 122
Mileage: 40946 km
Date: 2023.03.20
Time: 07:17:15
Coding: 0E4DDD
Coding: 00A8DD
Alarm horn:
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 122
Mileage: 40927 km
Date: 2023.03.20
Time: 01:43:51
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.5 V
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 40907 km
Date: 2023.03.20
Time: 00:57:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.0 V
Coding: 0471051811
Coding: 333135
Coding: 333135
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Generator:
Coding: 2DFFFF
Coding: 0D0000
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 120
Mileage: 40891 km
Date: 2023.03.15
Time: 00:40:56
Coding: 81170000
Coding: 150000
Data carrier:
Coding: 2F968A00
DV52
Australia
@Aaron1875 :Hi and thanks for your message.
hmm......... I've read your Ross-Tech discussion and Uwe's reply. I no longer participate on this forum because of Uwe's outrageous censorship whenever anyone questions his ultra right-wing stance on gun-control. Uwe is perfectly entitled to his views - but I won't be bullied, or censored in a public forum simply because I have a different view about the underlying cause for America's appalling slaughter of its own innocent school children!!!!
Anyhow, that's not the issue here - as for your tricky problem, I note that the software switches on BCM Byte 02, Bits 0-2 on this car has the value hex03. This means that the BCM believes that the the headlights are Xenon with both AFS and Main-beam assist.
If this car is fitted with an "adapter" - I assume that the vehicle left the factory production-line with halogen headlight fittings and as a result, the connector on the car-side of the headlight loom has a total of 10 x pin positions. Please confirm my assumption by eye-balling this connector.
I also note that BCM Byte 06, Bits 5-6 has the value hex00. This means that the BCM believes that the Main-beam lights have a H7 lamp base - which are typical for halogen bulbs! These 2 x software switches determine how the BCM treats the Xenon shutter function -so I'm not sure why the setting isn't either GLD, or H4 lamp base (which are typical for Xenon lights). My hunch is that this BCM might not support shutter operation.
Perhaps more curious, there appear to be lots of other "inconsistencies" in the long-code string for the BCM on this car - too many to fully list, but a few examples are:
  1. A UK car should be coded for RHD- but Byte00, Bit 0 =0=steering wheel on left-side
  2. Byte 01, Bit 0 =1=KESSY installed (i.e. keyless ignition). But the auto-scan report doesn't list a hex05 module (i.e. J518 module isn't present)
  3. Byte 01, Bit 3=1 = UGDO installed. Does this car have a Universal Garage Door Opener?
I have no idea how the BCM on this car was coded - maybe the previous owner simply thieved an entire long-code string from another car (I'm guessing of course).
I suggest that you post-up an adaptation channel database map for the BCM so that I can see the DNA of the hex09 module. This is called a "BCM admap". If you aren't familiar with this report - follow my instructions HERE.
A BCM Admap is a large file - when you are placing the file content in your next post, I suggest that you use the forum's "code" function like this:
  1. Copy the entire admap contents onto the clipboard (don't edit anything)
  2. Select the 3x dots shown in circled "1" on my screenshot
  3. Select the </> symbol shown in circled "2" on my screenshot
  4. Dump the admap data into the dialogue-box in circled "3" on my screenshot
  5. click on "continue"
Don
