Kuzya
- Toronto, Canada
- 2017 Sportwagon 4mo
Hi all, new to the forum!
Warning: Some of this information might be useful, but this is only my progress/side of the story
this is not a tutorial, not I or the forum will be responsible for any damage to your golf.
I have acquired some 2017 or 2018 golf R headlights. part # 5G0941753/4C would like to get them retro'd to my 2017 Golf Sportwagon 4motion
when looking up the part number they all have 3 modules on the bottom, ones i have got 4! further research directed me to mk7 egolf/golf r lights with High beam assist (FLA).
My golf was made in 2017 right before facelift meaning (I assume) I already have some of the newer mk7.5 software/hardware like the BCM
it is also a Trendline which is basic, no sunroof, manual parking brake, manual headlight switch, no light/rain sensor, manual cloth seats small screen etc. but at least its 4mo DSG.
I Have created a List of parts I'm using for this mod
also will be using OBDeleven
I already have a BCM - 5Q0937087 AN and it does come with correct pins.
Headlights 5G0941753/4C
HID Modules - 8K0941597 E
DRL Modules - 4G0907697 F
AFS Modules - 3D0941329 D
Gateway - 5Q0907530 AM
AFS Module - 7P6907357 D
Level Sensor - 5Q0512521 J
AFS Wiring kit - Aliexpress
Gateway adapter wire - Aliexpress
Here's my work so far
Step 1 - Sent the car to dealer to code Gateway ( remove CP and Return FeC codes ), after coding EPC Light was on, when scanning found error "checking coding/version of" P164700
at this stage of the mod, I had an accident, had replaced my entire right front suspension and subframe therefor halted the retrofit
after months of headache and complete front golf r brakes and suspension retrofit, I started looking into the HID's again.
Step 2 - Found the High CAN Gateway STILL needed FeC Coding meaning the dealer did not code it properly, I had to tell the dealer what to do, good reference was this attachment from Ross-tech forum.
THIS PICTURE IS EDITED. I removed the red marking from enable system because the correct one is "Function Clearing System(FES)"
Tech at the dealer already knew what was needed and coded it correctly , no more EPC light!
For next steps I used @George Ab's DIY: OEM Lighting Package (AFS Xenon) Retrofit.
Step 3 : Hardware and wiring - removed the grill, bumper and headlights followed same steps/wire routing as George, and faced exact issue George had! the wiring kit fuse plugs did not fit the fuse box housing I couldn't figure why, looked like they were the correct size but 3 hours down the drain, installed new headlamps, connected everything together reassembled interior and took a long nap till the morning. what I came up with is mini fuse extensions. spliced the extension, connected the fuse wires where they should go, test the lights and.... O.O!!! they work. well blinking/flashing with engine on. but work.
Step 4 : Coding - I compared my gateway and BCM to another golf similar to mine and figured my BCM doesn't have long coding and Gateway is coded differently. done some research, and thanks to @DV52 's answer on another forum confirmed I have the latest mk7.5 software meaning most of the long coding is completely different from the older mk7, meaning when it says you need to code BCM for Xenon lights Byte 2 bit 02, there's no long coding for BCM in OBDeleven. In my case It's in Adaptation
Looking at @DV52 's spreadsheet, George's Coding, and Harisg's post on drive2.com, I got the HID's low/high, turn signals and both drl's to work.
Mainly just followed George's coding except they were missing Leuchte 6 and 7 which are the main projector beams. This Snip was taken from Drive2.com.
Thanks to @DV52 I learned in my case to tell the BCM you have XENON go to BCM > Adaptation > Fernlicht assistent > and edit this string Erweiterte_Fernlichtsteuerung to the correct headlamp.
Step 5 - Current time I'm trying to figure how to code the AFS as I'm getting MIXED errors of incorrect coding and or not coded. possibly due to incorrect coding in "Fernlicht assistent > Erweiterte_Fernlichtsteuerung", also not sure where "Byte 06 - 20 Xenon - Shutter (PR-8IG/8IM/8IP) installed" is in new BCM, and also not sure how to do this part "VAGCOM changes to introduce AFS to CANBUS, Code AFS, Add Auto-leveling to Instruments - Use Vagcom to tell CANBUS module that AFS control module has been added. Select 19 CAN Gateway, then installation list and check the box next to 55 Xenon Range and execute."
I don't have VAGCOM, but I did borrow friends VCDS currently trying to figure it out.
Update 07/07/2021 I managed to get rid of the AFS Error on the dash. but still have incorrect coding, suspecting the AFS module.
Currently Erweiterte_Fernlichtsteuerung is set to "AFS, Fernlicht ueber AFS"
AFS Long coding 03 28 00 00 00 00 04 00
03 - Skoda Octavia (5E/NE) - Unable to change 03 to 02 I get an error (31) function not available. (trying to source another AFS)
28 - Leveling info via sensors not can / multi link rear axle AWD
04 - Static cornering light (according to SAE J582)
LeiMo links - 2F 00 00
LeiMo rechts - 2E 00 00
I get (31) function not available for either of them if i try to change
also I noticed the part numbers don't match that's probably why
U101400
U1081F0
U1082F1
Logs
Thanks
Kuzya
U101400
U1081F0
U1082F1
Logs
Code:
OBDeleven data log
Date: 2021-07-07 07:26
VIN: 3VW017AU6HM541230
Car: Volkswagen Golf SportWagen
Year: 2017
Body type: Variant
Engine: CXBB
Mileage: 68488 KM
01 Engine
System description: 1.8l R4 TFSI
Software number: 8V0906264M
Software version: 0001
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM18TFS0208V0906264M
ODX version: 001003
Long coding: 091D00122426002F0000
Trouble codes:
No trouble codes found
02 Transmission
System description: DQ250-6A MQB
Software number: 0D9300014M
Software version: 5004
Hardware number: 02E927770AS
Hardware version: H54
Serial number: TFK01703092554
ODX name: EV_TCMDQ250021
ODX version: 001001
Long coding: 0014
Trouble codes:
03 Brakes
System description: ESC
Software number: 5Q0614517AQ
Software version: 0400
Hardware number: 5Q0614517AF
Hardware version: H62
Serial number: 50997000000241
ODX name: EV_Brake1UDSContiMK100ESP
ODX version: 036010
Long coding: 04FA6AA12424096D8079030380C3292056249001C001943400435050C009430000000012121212B835351919323200
Trouble codes:
08 Air Conditioning
System description: AC Manuell
Software number: 5GM907426E
Software version: 1801
Hardware number: 5GM907426E
Hardware version: H03
ODX name: EV_ACManueBHBVW37X
ODX version: 004134
Long coding: 02020004200100000000000000000002
Trouble codes:
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087AN
Software version: 0223
Hardware number: 5Q0937087AN
Hardware version: 032
Serial number: C8640504170161
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 017002
Subsystems:
System description: WWS 160616
Software version: 0551
Hardware version: 043
Serial number: 97022066160624105648
Long coding: 0E4DDD
Trouble codes:
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655T
Software version: 0830
Hardware number: 5Q0959655T
Hardware version: 011
Serial number: 003MHM03TZ35
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002144
Long coding: 8CCCFC00000000005000001AC24800000065
Subsystems:
System description: BF-Gewichtss.
Software version: 0022
Serial number: IBH0000000000073KDSV
Long coding: 303132
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 35700000000AB274D22N
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 35800000000C06C8D12R
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Hardware version: 000
Serial number: 3510001C324CDB23F135
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 35200019924CEFC104FM
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3550002B924F3843F2EJ
Long coding: 2D2D2D
System description: FrontSensor_P
Serial number: 3560002BB24F3841E0DG
Long coding: 2D2D2D
Trouble codes:
16 Steering Column
System description: Lenks. Modul
Software number: 5Q0953507GH
Software version: 0140
Hardware number: 5Q0953549E
Hardware version: 003
Serial number: 12031704400067
ODX name: EV_SMLSKLOMQB
ODX version: 020002
Long coding: 0410
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 5G1920740B
Software version: 8311
Hardware number: 5G1920740B
Hardware version: 244
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009051
Long coding: 0BB4100AA980880902086A001000000000000000
Trouble codes:
19 Gateway
System description: GW MQB High
Software number: 5Q0907530AM
Software version: 2265
Hardware number: 5Q0907530M
Hardware version: 212
Serial number: 30091610802959
ODX name: EV_GatewConti
ODX version: 013020
Long coding: 0901000870085900FA0000021E0F00000001050000000000000000000000
Subsystems:
System description: WECHSELRICHTE
Software version: 0041
Hardware version: H55
Serial number: 0327102
System description: E221__MFL-DC1
Software version: 0103
Hardware version: H17
Serial number: 29170000218430117057
Long coding: 30FFFF
Trouble codes:
22 All Wheel Control
System description: Haldex4Motion
Software number: 0CQ907554H
Software version: 7083
Hardware number: 0CQ525130
Hardware version: H52
Serial number: HA1-00029.10.1600010507
ODX name: EV_AllWheelContrHA1VW37X
ODX version: 004013
Long coding: 0001
Trouble codes:
42 Driver Door
System description: TSG FS
Software number: 5Q0959393E
Hardware number: 5Q0959393B
Hardware version: 020
Serial number: 1304170605007F
ODX name: EV_DCUDriveSideEWMINKLO
ODX version: 006003
Long coding: 003003200000020000000000
Subsystems:
System description: Fond FHSG DRV
Software version: 0002
Hardware version: 007
Serial number: 00000000000006218561
Long coding: 011000
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5QM909144A
Software version: 1072
Hardware number: 5QM909144A
Hardware version: 171
ODX name: EV_SteerAssisMQB
ODX version: 013144
Long coding: 0102
Trouble codes:
52 Passenger Door
System description: TSG BFS
Software number: 5Q0959392E
Hardware number: 5Q0959392B
Serial number: 190417060506SG
ODX name: EV_DCUPasseSideEWMINKLO
ODX version: 006003
Subsystems:
System description: Fond FHSG PSG
Serial number: 00000000000006068263
Long coding: 091000
Trouble codes:
55 Headlight Regulation
System description: AFS-ECU
Software number: 7P6907357D
Software version: 0090
Hardware number: 7P6907357A
Hardware version: H07
Serial number: --------------
ODX name: EV_HeadlRegulVWAFSMQB
ODX version: 001120
Long coding: 0328000000000400
Subsystems:
System description: LeiMo links
Hardware version: H01
Long coding: 2F0000
System description: LeiMo rechts
Long coding: 2E0000
Trouble codes:
U101400 - Control module incorrectly coded
static
Date: 2021-07-07 07:25:19
Mileage: 68488 km
Priority: 1
Malfunction frequency counter: 1
Unlearning counter: 85
C1081F0 - Left headlamp power output stage not coded
static
C1082F1 - Right headlamp power output stage Incorrect coding
static
5F Multimedia
System description: MU-S-S-US
Software number: 3Q0035844A
Software version: 0753
Hardware number: 3Q0035844A
Hardware version: 710
ODX name: EV_MUStd4CDELP
ODX version: 001001
Long coding: 02730200FF00000051220001001828001F0100D40120010002
Subsystems:
System description: ABT_Std-2_Nav
Software version: 8130
Hardware version: H51
Serial number: VWZ6ZHV0673217
Trouble codes:
B201A00 - Checking software version management
static
Thanks
Kuzya
