Kuzya
- Toronto, Canada
- 2017 Sportwagon 4mo
@DV52 thanks a lot it works well! About the long code, I've never touched that string, assuming it came like this from factory [Edit - looked up my backup before the upgrade, and it has the same long code]It certainly is not "the right one". This BCM is the newer type that does NOT use an active long-code string.
I have no idea how, or why 0E4DDD is present in your BCM - but it's most definitely not correct !! My advice -remove the long code value (enter ALL zeros)
For your right High-beam problem do this:
Don
- Leuchte11SHUTTER RB22 - Lichtfunktion A 11 >Fernlicht rechts
